Go to Post I bet Andy Baker would totally own JVN in a 1v1 dodgeball fight. - Greg Marra [more]
Unread 15-02-2009, 01:01
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Re: Aluminum angle on bumpers
Originally Posted by Tristan Lall View Post
That's a perfect example of two problems with the rules this year.
One: if the angle is optional, why don't the rules say so? (And why haven't the rules been updated, given that this question was first raised weeks ago?)
The problem is with graphic communication. The GDC supplies graphics in the Robot Manual to help describe what they are specifically referring to in certain rules. However, the graphics may contradict other rules. Unfortunately, the graphics can lead readers to conclusions the GDC never intended. Then us mere mortals rely on the Q/A to clear the confusion.
I am assuming in Figure 8-1, you are supposed to infer that the use of aluminum angle is optional because no bumper rule expressly tells you to use aluminum angle.
In Figure 8-2 (I know, beaten to death), you are not supposed to infer anything and simply look at the "OK" corner configurations.
Two: if the Q&A advises something that isn't directly supported by the rules, what do teams do? (And what do you expect the inspectors to do? Assume that a Q&A is as good as a rule change, and make the teams comply with the Q&A?)
The GDC would say they provide clarification, meaning the Q/A responses are direclty supported by the rules. (that sentence may get me in trouble)
For me personally this has been a very tiresome year. The GDC wants a very specific bumper design. Unfortunately, the rules seem to be very non-specific and the graphics are confusing. Some folks around here find it simple and straight forward. They think that anyone who doesn't is either: A.) Trying to advance an illegal robot design, B.) lawyering the rules, C.) a moron; which have led to some viscous personal attacks. Quite frankly I don't pour my seemingly dwindling free time into something that I think is a waste of time. I think the rules discussions are important because it provides a platform for the GDC to understand where our thought process is- how people, who don't know the GDC's intent, interpret the rules.
Unread 15-02-2009, 10:05
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Of course the tricky part is knowing just what you are supposed to infer
That's why we have the Q&A, I guess!
Unread 18-02-2009, 08:51
Do your best and the Inspection Team will help, if needed, get you the rest of the way. We have and will be discussing the bumpers on our phone conferences and your inspection team will be up to date on the GDC decisions at each event. With the 18 lb limit, construction should not be a problem. Bowing to the Great Karnack, I will predict that we will see teams with issues using weak fabric, something other than 3/4" plywood backing, hard parts in the corners, and less than rigid fastening systems. And I also predict we will see teams with sections less that 6" long, and no robot structure to back up the bumper.
Unread 18-02-2009, 08:59
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
To the more experienced teams out there - please consider bringing plenty of extra fabric, aluminum brackets, pool noodles, plywood and "robust fastener systems". Since these can all be unmodified COTS items, you can bring as much as you'd like.
Your robot inspectors and rookie teams (ie your potential alliance partners) will be VERY grateful. There will probably be a LOT of bumper re-building on Thursdays.
Russ
Unread 19-02-2009, 10:10
Unless you've pre-cut your COTS 4' x 8' sheet of plywood into bumper width strips...
Luckily, I don't believe we'll be anywhere close to our 40 lbs of fabricated parts and can donate some of our weight allowance to these spare bumper parts.
Unread 19-02-2009, 14:57
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
There is a simple solution to that. Leave the pre-cut strips in your vehicle and give them to the other team in the parking lot. Then they become part of the other team's allowance, not yours.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 19-02-2009, 17:53
Bob Steele's Avatar
On the RIBMEATS bandwagon....
AKA: Bob Steele
Great idea Chris...
Perhaps a bumper kit.... strips of plywood 5" wide... t- nuts... 1/4 - 20 bolts... fabric of a neutral shade...staple gun and plenty of staples...
Left outside in the van/trailer/car
We will be doing that... enough for at least 3 robots...
perhaps even more plywood strips.... the fabric could be reused..
R
Unread 20-02-2009, 08:33
I recommend that you let your know Lead Robot Inspector know if you've got extra bumper parts available. He/she would appreciate being able to point teams in your direction.
Russ
/edit
And, by the way, THANK YOU VERY MUCH (in advance) for bringing such goodies to your regional!!!
edit/
Unread 20-02-2009, 19:03
GaryVoshol's Avatar
Cogito ergo arbitro
Russ
/edit
edit/
Those wouldn't be fabricated bumper parts now, would they?
(since 2004)
Unread 20-02-2009, 19:14
AdamHeard's Avatar
Lead Mentor
It's too late this season, but next season maybe we should just QnA the entire manual the day QnA opens.
Either that or boycott the QnA, nothing is illegal until it's asked apparently.
Team 973 is bringing a lot of bumper supplies to regionals, and a lot of premade 6" sections. This is not going in our withholding allowance, we are bringing it. Period. End of story.
Off Topics, but wouldn't this make it legal to split your robot into 3 40 lb sections, and have it entirely brought in at the regional?
EDIT: Would anyone consider bright freaking orange a nuetral shade?
Unread 20-02-2009, 19:49
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Bingo! Hopefully next year they can clarify the bumper construction, it's hard to be in full compliance when the rules aren't fully clear.
We have our bumpers built with the plywood backing, pool noodles, fabric stapled in place and 3/4" aluminum angle screwed over the fabric where the plywood is. We also have the tee nuts in the plywood for the bolts to fasten the bumpers.
We DO have steel angle pieces that fasten those bumper bolts to the robot frame. Basically the steel angle has bolts on both sides, one to hold the bumpers to them and the other to hold the angle to the robot frame.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Right Angle Transmission StorminNormin1 Motors 6 07-02-2007 12:51
Angle of Launcher ThisGuyRight Rules/Strategy 3 24-01-2006 11:05
Angle from X,Y Astronouth7303 Programming 18 19-04-2004 22:08
Slotted Angle Aluminum hinge87 OCCRA 1 09-10-2002 18:15
'Aluminum Angle/box/tube'-- copy of posting in General archiver 2000 0 24-06-2002 00:11
