Go to Post I think this says it all... It's Fantasy FIRST on Chief Delphi. - Zach O [more]
Unread 08-02-2009, 19:57
Straberrie's Avatar
Straberrie Straberrie is offline
The Plague
AKA: Rebecca
FRC #0375 (Robotic Plague)
Straberrie will become famous soon enough
Digital Inputs?
Hello!
I am using C++ and I have a question about implementing Digital Inputs in the code... Is Get() the function that means "true" or no? I basically want an if statement saying if DigitalInput1 is true, then this, but I am unsure which function to use to set the condition... =(
Thank you!!!
Team 375: The Robotic Plague
Current Robot: I-Chihuahua
Last Event: Big Apple Breakaway
Unread 08-02-2009, 20:32
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Digital Inputs?
DigitalInput DigtalInput1(1);//port1
if (DigialInput.Get())
do this
else
do that
Watchdog.Kill();
Unread 09-02-2009, 20:07
Straberrie's Avatar
The Plague
AKA: Rebecca
Re: Digital Inputs?
Thank you!!!!!!
Unread 14-02-2009, 23:27
programMORT11
Posts: n/a
Re: Digital Inputs?
how would you do this in C without adding the C++ digitalinput objects? could you cast the UINT32 GetDigitalInput() function results to boolean?
Unread 15-02-2009, 01:47
Redneck's Avatar
Redneck Redneck is offline
Hacker Hick
AKA: Jamie (2.0) Moran
FRC #0599 (Robodox)
Redneck is just really niceRedneck is just really niceRedneck is just really niceRedneck is just really nice
Send a message via AIM to Redneck
Re: Digital Inputs?
I don't believe so, because C doesn't have a bool data type. Traditionally boolean logic is done in C with integers with 0 for false and 1 for true. It'll still work the same way. If you have
if(GetDigitalInput()){
    // something
it'll work the same way as the C++ bool value.
Which badges can you claim?
Using Interrupts on Digital Inputs Analog C/C++ 6 03-02-2009 23:05
Digital Inputs KRibordy C/C++ 5 25-01-2009 00:35
reading multiple digital inputs angelkat Programming 2 25-01-2009 00:22
Digital inputs, bandwith, errors? Micah Brodsky Programming 7 20-01-2003 16:08
Analog vs Digital inputs? f22flyboy Programming 8 08-11-2002 22:18
