Go to Post theres nothing more macho than something made entirely out of diamond plate. - Dan9874123 [more]
Unread 15-02-2009, 02:06
coolperson987 coolperson987 is offline
FRC #1798
coolperson987 is infamous around these partscoolperson987 is infamous around these parts
CIM Legality
In the rules section <R51> it states:
"D. One or two additional 2-1/2” CIM motors (part #FR801-001 and/or M4-R0062-12) in addition
to those provided in the Kit Of Parts. This means that up to four, and no more, 2-1/2” CIM
motors can be used on the ROBOT."
So, the question then is, Can a CIM motor of a larger or smaller size than mentioned in <R51 D> (2-1/2” CIM motors) be legally used on the robot (that are not of a previous robots)? By all suppositions and according to <R52 A> "(Motors that are prohibited)Electric motors and/or servos different from, or in addition to, those in the Kit of Parts, with the exception of those specificalLy PERMITTED in <R51>.". This implies that becuase motors that are not of the sizes of the CIM motors mentioned in <R51> are allowed they are therefore mentioned in that section and are thus legal.
Unread 15-02-2009, 02:12
Mike8519's Avatar
Mike8519 Mike8519 is offline
FRC #0303 (TEST Team)
Mike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really nice
Re: CIM Legality
You may only use the CIM motors provided and a maximum of 4.
Unread 15-02-2009, 02:35
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Re: CIM Legality
<R52> prohibits motors other than those in the kit and those specified in <R51>D. The bolded text from <R51> specifies the 2 1/2" CIMs and part numbers, so any CIMs you use other than the two provided in the kit must be the same 2 1/2" size/design motor.
Unread 15-02-2009, 02:44
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Re: CIM Legality
I see what you mean. <R52> says that motors not prohibited are those specifically allowed by <R51>, which says specifically permitted motors are the ones in the KOP among other things. This means that the motors your team received in its KOP are legal, not that all types of motors that come in the KOP are legal in any quantity.
While the logic is a little fuzzy, the intent is clear: you can use all motors permitted by <R51>, and can use no motors not permitted by <R51>.
One thing FIRST discourages is "lawyering" of rules; just because there's some slightly ambiguous wording in one of them does not mean you should try to pick it apart to gain an advantage. Besides, I doubt you'd be able to convince an inspector that your robot was legal if you did what you're suggesting.
Unread 15-02-2009, 02:45
FRC #1798
Re: CIM Legality
Rule 51 D says 4 and no more 2 1/2" CIM motors. What about Cims of other sizes?
Curious because it doesn't say '4 CIM motors total- of any size'.
Unread 15-02-2009, 03:10
GUI GUI is offline
AKA: Gary
Re: CIM Legality
The rule boils down to this: you may use a grand total of 4 Cim motors identical to the ones in the kit. You may not use the larger 3" Cims that have been provided in previous years.
Unread 15-02-2009, 09:53
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: CIM Legality
Rule <R52> says you can't use any other size of CIM, since they are different from those provided in the KOP. And the ones permitted by <R51> are the 2-1/2" size.
<R52> Items specifically PROHIBITED from use on the ROBOT include:
A. Electric motors and/or servos different from, or in addition to, those in the Kit Of Parts, with the exception of those specifically permitted by Rule <R51>.
witricity legality? XXShadowXX Electrical 68 10-05-2008 07:58
NJ Regional: IR Legality LH Machinist Control System 17 29-02-2008 06:27
Legality question SonicKidGJ VEX 6 13-01-2008 14:00
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
legality question rbayer General Forum 8 15-09-2002 00:25
