Go to Post The gates were removed for this game so that it would be easier to get the Zamboni in and out when the field was resurfaced after each round. - dlavery [more]
Unread 15-02-2009, 02:14
Valkyries_698's Avatar
Valkyries_698 Valkyries_698 is offline
Palmam qui meruit ferat
AKA: Tim
FRC #0698 (Microbots)
Valkyries_698 is a jewel in the roughValkyries_698 is a jewel in the roughValkyries_698 is a jewel in the roughValkyries_698 is a jewel in the rough
Send a message via AIM to Valkyries_698
698 ball lifter
Check out the mechanism we built to lift up the balls to our shooting/dumping system. Still has some hangups but we should be able to have them kinked out by competition.
http://netblues.org/tim/index.php?op...ideos&Itemid=8
Unread 15-02-2009, 03:09
Rizner's Avatar
Rizner Rizner is offline
FRC #2425
Rizner has a spectacular aura aboutRizner has a spectacular aura about
Re: 698 ball lifter
Looks good - are the balls purposely going to the side, or is that the hangup you're mentioning? If you're trying to get them over into the front, I think if you curve the back piece to go along with the track a bit it should work.
-Rizner
Unread 15-02-2009, 06:59
GaryVoshol's Avatar
Cogito ergo arbitro
Re: 698 ball lifter
Did you get permission to post the Lunacy animation from Kickoff?
(since 2004)
Unread 16-02-2009, 03:34
AKA: Tim
Re: 698 ball lifter
@Rizner
we were sending the balls to that side so that they could load into our basket from the side. the hangups occur when a extremely damaged ball tries to go up the loader but we believe most of those problems have been solved. We also changed the loader to send the ball through the center of those two posts you see in the video.
@GaryVoshol
for educational purposes......
goto youtube and type in lunacy FRC
698 frame photosynth Valkyries_698 Robot Showcase 0 28-01-2009 20:42
698: Amazing New Website Moheeb698 Website Design/Showcase 10 12-03-2008 15:07
Who's a Lifter? LordKronus Rules/Strategy 2 21-01-2007 00:00
pic: Teaser Team 698 Alex698 Extra Discussion 5 08-03-2006 18:40
pic: Team 698 Collage Alex698 Extra Discussion 1 22-01-2005 21:36
