#7
Re: Arcade Drive Issue and Pnuematics
Well COULD anyone look at our code if anyting is incorrect becuase our robot should be able to 1)drive arcade, 2) have a second joystick for a motor to runs with a button to set off the soleniod, 3) Also be able to turn the compressor on and off by a button on the joystick !!!!!
| Non-Arcade Drive causes problems in Autonomous... | pinballwizard96 | NI LabVIEW | 2 | 01-02-2009 20:45 |
| Arcade/Tank Drive Malfunction | piedmont | Programming | 2 | 19-01-2009 17:37 |
| EASY C PRO help tank drive issues!!! can any 1 solve this programming issue? | mayazk | Programming | 2 | 16-02-2008 02:17 |
| Arcade Drive | Anfony | VEX | 4 | 08-11-2006 19:46 |
| vex programming arcade drive setting | Michael Leicht | FIRST Tech Challenge | 3 | 17-10-2005 21:26 |
