Go to Post The real key to drive team coaching is to tie your jacket around your waist. Got a couple championship rings that way. - TravusCubington [more]
Unread 12-02-2009, 01:25
fqzeng's Avatar
fqzeng fqzeng is offline
FTC #0455
fqzeng is an unknown quantity at this point
[FTC]: [FTC]: Motor Problems
My motors don't seem to respond to any commands from my programs. I'm using RobotC and when I use the debugger it says that it's getting values from my joystick and the motors are moving; however, the motors aren't actually moving.
I'm sure all the wiring is done correctly and I JUST charged the batteries.
One thing is that we don't have encoders on our motors yet, but I'm pretty sure we don't need encoders to be able to move our motors. D=
Unread 12-02-2009, 06:49
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: [FTC]: [FTC]: Motor Problems
sounds like you aren't getting power to the motors. check your fuse and your wiring connections.
Unread 15-02-2009, 11:38
astephen68's Avatar
astephen68 astephen68 is offline
Build, Scout, Drive
AKA: Stephen
VRC #0478 (Mustang Robotics)
Team Role: Scout
astephen68 is just really niceastephen68 is just really niceastephen68 is just really niceastephen68 is just really nice
Also check if the connection to the nxt is throught the motor controller first not the servo
Soutern Ontario Championship
-Finalists
-Winners of the Drivers Challenge
-Finalists
Unread 16-02-2009, 19:12
cbhl cbhl is offline
AKA: Michael C
FTC #0481 (Thornlea Robotics)
cbhl is on a distinguished road
Check all wiring is done properly. Also, I believe the DC controllers require the battery to be plugged into a particular set of battery terminals, although I'm not 100% sure -- you could try connecting the battery to the other set of battery terminals and seeing if it helps.
If you're using the new JoystickDriver.c and have the diagnostic info displayed, you should be seeing the battery voltage as Ext Batt -- it should be around 12 V if your battery is freshly charged. A lower value would likely indicate a loose cable or something.
Finally, if you don't have the encoders set up, make sure that you uncheck "PID Control" in the Motor/Servo/Sensor setup dialog in RobotC -- if I recall correctly, the motors won't work if "PID Control" is checked and you don't have an encoder. ("PID Control" tells RobotC to regulate the motor speed using the encoder.)
Just my two cents.
Michael
Thornlea Robotics (FTC Team #481/#3431)
Programming Team Lead
http://thornlearobotics.ca/
[FTC]: Rhode Rage (FTC 121) is in need of a motor encoder wire Rick FIRST Tech Challenge 2 02-02-2009 01:56
[FTC]: Random Error with FTC motor control Xaphiinia FIRST Tech Challenge 2 01-12-2008 15:39
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
[FTC]: [FTC] Motor Controller problems michael714 FIRST Tech Challenge 4 14-10-2008 00:33
[FTC]: FTC]: FTC Champ Tournament - Ontario (Scoring Breakdown) Mr. Lim FIRST Tech Challenge 2 03-03-2008 11:54
