Re: Buttons and Pneumatics Help
I notice that you are setting PWM5 and PWM6 motors to 255 immediately. If the breakers are continually tripping, maybe you should set these to a control and start with the speed at zero initially and see if you still trip the breakers.
Also, did you change the solenoid controls to constants as I suggested? If you want the stand alone deployment to be Set as Startup, right click the build specification and select "Set as Startup". |
| joystick and extra buttons | TEAM1949 | Programming | 3 | 18-02-2008 13:22 |
| Help Programming Buttons | LordFrz | Programming | 3 | 14-02-2008 13:55 |
| Buttons, Buttons and more Buttons (2006) | Freddy Schurr | Team Organization | 11 | 14-12-2005 21:36 |
| Buttons and Other Giveaways | Phil Paspalas | General Forum | 29 | 30-01-2005 18:00 |
| Looking for some help with buttons and pins... | Amanda Morrison | General Forum | 4 | 26-02-2003 17:32 |
