Go to Post Mmmm scrap used parts. Dismantle, find data sheets and have fun.:D - techhelpbb [more]
Unread 15-02-2009, 13:24
Re: Wiring previous-year banner sensors
Originally Posted by Cjmovie View Post
We had the NC/NO hooked up to the various colors of a PWM line, however, the ends of these went to the proper points on the digital sidecar / analog breakout. We had both NC/NO wired on one wire with it sideways on the line of signal inputs (perpendicular to the normal method) so that we could test both at once - nil.
I can't tell what you mean here. The sensor signals don't go to a PWM port; they go to a DIGITAL I/O port. I can't think of a good reason for any signal to be connected to both a Digital Sidecar and an Analog Breakout. In any case, if you connected both black and white outputs of the Banner sensor to the same wire, you'd always see the result at ground.
Wiring Banner sensors ten3brousone Electrical 6 01-03-2005 20:03
Wiring Banner Sensors ten3brousone Electrical 1 17-02-2005 03:16
Banner Sensors ESchneider Control System 8 18-02-2004 12:17
Banner sensors cadets Electrical 3 04-12-2003 14:30
banner sensors edomus General Forum 7 20-11-2003 19:43
