Go to Post The moral of this story: A healthy respect for the customer, dedication to your job, and a positive outlook can make even the most trivial and monotonous job into a wonderful experience. - Molten [more]
Unread 14-02-2009, 22:08
nekng's Avatar
nekng nekng is offline
Former 1836 Captain
AKA: Nate
FRC #1836 (MilkenKnights)
nekng is on a distinguished road
Ultrasonics / Sonar
I have spent literally hours trying to figure this out, could someone post every single step involved in programming ultrasonic sensors using the interactive robot class?
Unread 14-02-2009, 23:43
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Ultrasonics / Sonar
You need to give more details....
What sensor are you using, and maybe a bit of the code you are trying to use?
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 15-02-2009, 00:40
nekng's Avatar
Former 1836 Captain
AKA: Nate
We are using vex ultrasonic sensors.
Unread 15-02-2009, 00:50
wt200999's Avatar
Texas Instruments
AKA: Will Toth
The code should work fine with that, have you looked at page 46 of the "C Programming Guide for FRC"? What kind of results do you get.
Unread 15-02-2009, 01:34
Shira Shira is offline
FRC #1836
Shira is an unknown quantity at this point
Hey, I'm working with Nate (who started this thread) on the code and here's what happens:
In the class variables declaration:
Ultrasonic *m_ultra;
double range;
static const UINT32 pingChannel=1;
static const UINT32 echoChannel=2;
In the constructor:
m_ultra = new Ultrasonic(pingChannel, echoChannel);
m_ultra->SetAutomaticMode(true);
range = m_ultra->GetRangeInches();
But when I print out the range I get only zeros. Actually, I've gotten other values with that code occasionally (still not functional though, just random values that don't update often at all), but we tested so many sensors and configurations that I am not convinced it is a hardware problem.
Also, I can't get that sample code from the Programming Guide to work. I get compiler errors. I've tried a number of things, but unless i use that code with pointers, I can't get the code to compile.
So can anyone give some sample code, or detailed instructions, on how they set up their ultrasonic sensors?
Unread 15-02-2009, 13:44
Originally Posted by Shira View Post
double range;
But when I print out the range I get only zeros. Actually, I've gotten other values with that code occasionally...
How are you printing it? If your format specifier doesn't match the variable type, it won't work properly.
Unread 15-02-2009, 16:35
nekng's Avatar
Former 1836 Captain
AKA: Nate
We are using a %f to print it.
Unread 15-02-2009, 20:11
In the constructor:
Are you ever setting range anywhere else? The assignment in the constructor most likely occurs before any echoes have been received, so it won't be a valid value. I believe calling m_ultra->GetRangeInches() later should give you the current range.
Unread 15-02-2009, 23:28
FRC #1836
We're calling it in Autonomous Periodic or Autonomous Continuous (I'm not sure where we're going to put our code yet but I think it is all going to go in autonomous continuous unless there is a good reason not to..)
There is no other setting of the range anywhere else. I declare the var in the class and then I set the range to the value returned by the get range function.
Unread 17-02-2009, 14:03
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
Check to see if the Range is valid, using the function:
IsRangeValid()
It will return a boolean letting you know if the sensors have fired yet and some result has come back.
My Blog!
sonar is being lame Sparky_68 Programming 5 13-02-2009 00:55
How to program sonar FearlessLeader C/C++ 1 11-02-2009 22:39
Sonar Sensor help eagleslg Programming 9 05-05-2008 21:14
Ultrasonics Ctx32 Programming 1 06-06-2006 10:56
Ultrasonics Ctx32 FIRST Tech Challenge 3 06-05-2006 14:32
