heres what happens:
we have the laptop plugged by ethernet cable into the driver station. we will deploy the code we're working on and everything seems fine. the robot runs and all functions are OK till we stop. if we unplug the laptop and start the robot again nothing happens. its like we have to have a computer attached to the driver station to deploy each time we want the robot to work. it seems like the program we deploy is not saving to the cRIO. How do we get our code to save on the cRIO so that it runs when it is powered up and without a laptop attached anywhere in the system? Is there a switch or something im supposed to flip or a special Save button? By the way, im not very computer savy so explain it in as much detail as possible please. thanks. |
Re: Code deploys but does not save to cRIO
Ok, if you go to the project explorer window, and go down to where it says Build Specifications, then click the plus sign. Right click on FRC Boot-up Deployment, and click Build. Let it do its thing, then right click and hit run as startup. (you need to be communicating with the robot for this step). let it go until it asks to reboot. say yes. It should now do the code you built every time it boots.
I am having the same problem, but I dont have the FRC Boot Up Deployment. Is there a way i can get it?
It is a part of the template projects, both basic and advanced. If you don't have one, you can build it yourself. Here are the basic steps.
Go to the cRIO Build specs, right click and add a new RT EXE build spec. In the dialog that comes up add in the Robot Main as the startup VI, and I think that is it. Greg McKaskle |
You probably have only one build specification, which was created properly for you when you created the LabVIEW project from the robot template. It might be called "FRC Basic Robot Deployment" or something similar. Right-click it and you should see the menu containing the Build and Run as Startup options.
Awesome!
I see it now! Thanks guys, I would have never put that together by myself. That saved me a lot of headache. |
#7
I'm trying to follow Paul's instructions, but every time it starts to deploy, it loses connection and then says it was completed with errors. Has anybody else had this problem?
#8
We also have the problem with errors.
For some reason, it doesn't like it if we have more than one open joystick, open motor, etc. When it runs, only one of each type of vi can run. Is there maybe a way to rename these? |
#9
The template code has multiple opens, so I don't think there is an issue there. What isn't allowed is doing multiple opens of the same resource without closing the first one. Instead of doing this, you will normally want to branch a wire or sore the refnum and use it in other loops.
Greg McKaskle |
#10
We're having the same problem and tried following what you said but there's no plus box next to build spesifications. What do we do now??
#11
Did you start from a normal default Robot Project, or do you just want to download an example permanently? The examples don't normally have a Build Specification, but the default code that you should really begin with, does. Last edited by Mark McLeod : 02-01-2012 at 11:23 AM. |
#12
Thanks. We figured it out.
| The Program Compiles and Deploys, but the sidecar doesn't connect | pj174208 | Programming | 1 | 02-14-2009 06:26 PM |
| Crio network light does not light when camera plugged in | Bongle | Programming | 16 | 01-16-2009 11:00 AM |
| cRIO wont save program | Arcre | NI LabVIEW | 5 | 01-07-2009 11:45 AM |
| URGENT HELP: IR board TRAINS but does not RECIEVE | dan_h | Sensors | 6 | 02-20-2008 08:31 PM |
| frc_camera not working but labview does | Issues | Programming | 7 | 01-18-2006 07:23 PM |
