Go to Post Call it confidence, call it ego, call it what you want, but the fact of the matter is you need to be humble or someone will humble you. - Dan Richardson [more]
Unread 14-02-2009, 21:25
iblis432 iblis432 is offline
Co Captain/Chief Programmer
AKA: Bobby
FRC #2106 (Junkyard Dogs)
iblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to behold
Getting Html and/or text reports from cRIO
I have recently stumbled upon a few VI's in regards to writing up reports. I found a few but I think most of them were made for labview, not neccasarily labview with the cRIO. There is a MAX VI that can apparently write HTML and XML report files, but i see no way to designate a path. As for plain text file reports, i can designate a path, but when i attept to specify a ip address, im worried it will write the report on the RIO rather then on our labtop. I could have it write solely from the computer, which i will do first anyway, but i was wondering if anyone knew how to tell it to report on the cRIO but have the output be on the labtop, or at least if it does save on the RIO, how to pull my report out of the RIO for reviewing.
Unread 14-02-2009, 22:18
Re: Getting Html and/or text reports from cRIO
It will get a little more complicated, but here is the way to do it.
Build a VI to produce the report, put the VI under the My Computer target instead of the cRIO. When you want it to run on the laptop, you will use the VI server to run the VI. There are plenty of examples for how to use it to remotely execute a VI.
Greg McKaskle
Unread 14-02-2009, 23:18
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
If you must save the file on the cRIO file system, you can put a USB flash drive (aka USB stick) in the cRIO USB port and write it to the flash drive. Then, obviously, you can remove the USB flash drive and copy the file to the laptop.
Unread 15-02-2009, 01:24
Originally Posted by airnate View Post
...you can put a USB flash drive (aka USB stick) in the cRIO USB port...
What cRIO USB port?
Unread 15-02-2009, 12:54
Oops, beg your pardon. I guess the USB port was removed for the FRC version of the cRIO. My mistake.
Unread 15-02-2009, 14:34
dqmot17's Avatar
dqmot17 dqmot17 is offline
Orange Hat
FRC #0247 (Da Bears)
Team Role: Webmaster
dqmot17 can only hope to improve
Send a message via AIM to dqmot17
you can ftp to your cRIo. I used it successfully.
go to a browser and type ftp://10.xx.yy.2
2009 Championship Finalists & 3 Blue Banners
Whos getting a second CRio lenny8 FRC Control System 17 12-03-2009 15:09
Help Getting cRIO Feedback rholokleolke C/C++ 3 29-01-2009 17:13
Getting Packets from the cRio rfrank Programming 2 17-01-2009 22:35
Getting help from your principal and local school district Carl Gao General Forum 11 25-09-2008 00:36
OI is getting bad data from RC and vice-versa X-Istence Programming 10 27-02-2006 23:40
