Go to Post CD, you are crazy!!! - Tottanka [more]
Unread 15-02-2009, 12:13
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
Paramaterizing Case Statements
Hey all, i have a quick question. I know that in C, we could use variables in case statements (e.g. if(time_elapsed<time_to_intercept){...} (where time_to_intercept was calculated earlier in the code)). Is there any way we can do that in Labview?
Thanks!
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 15-02-2009, 13:58
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
Re: Paramaterizing Case Statements
Yes. And no. (there, that was simple, right?)
The problems is that your question is not as simple as it may seem. It really depends on exactly what you are asking.
Yes, you can perform a calculation and wire it to an indicator and then use the indicator's local variable later in the program to read back the value. However, in general, if you can keep your value in a wire (i.e. instead of using local variables), your code will be faster and use less memory.
Note that for the size of the FRC projects, this is really not likely to make a difference in performance, but it's something to keep in mind as you use LabVIEW.
If you are asking if you can actually evaluate expressions as part of the case statement itself, then the answer is no. All of the case expression needs to be evaluated up front prior to the actual case statement.
What you could do is use enumerated types or strings to help make the case statement more legible. If you pass in the enumerated type or string for which you wanted to execute code, the case statement would display text for each case (more like a C switch statement).
Unread 15-02-2009, 14:03
http://zone.ni.com/reference/en-XX/h...ce_structures/
You can use a range for your cases, as described in the page above.
Unread 15-02-2009, 14:08
paulcd2000's Avatar
AKA: Paul Dagnelie
That was what i wanted to know. Thanks. i'll deal with it by doing the logic outside the case structures and giving the results as booleans.
Unread 15-02-2009, 15:18
This question seems pretty much wrapped up, but I'll add one thing.
Because of dataflow, writing to a local in one location and reading for the case in another is usually not what you want. The local may well be read immediately, before you code writes to it. Wires don't do that. So to summarize, watch for race conditions and think in parallel when using local or global variables.
Greg McKaskle
printf statements Hazmatt Programming 2 09-02-2008 16:09
Using While Statements Sykan Programming 6 27-01-2008 12:29
impossible statements Dan Zollman Math and Science 28 20-08-2005 18:34
Conditional #define Statements Ian W. Programming 3 14-02-2004 18:14
Else Statements!!! Adam Shapiro Programming 9 22-12-2002 01:27
