Go to Post One wondered why they couldn't practice in the gym that day - because the robotics team had it reserved was the answer. "Oh, we have a robotics team?" Sigh. This is a team with a low number. They've been around for at least a dozen years. There's still a lot more culture-changing to do. - GaryVoshol [more]
Unread 14-02-2009, 14:28
Chris11246 Chris11246 is offline
FRC #1647
Chris11246 is an unknown quantity at this point
Drivers station problems
When we try to put new code on the cRIO our drivers station switches to WatchDog mode when enabled and the voltage of the battery goes to 0V. Can anyone help?
Unread 15-02-2009, 15:33
ringo115 ringo115 is offline
FRC #1647
ringo115 is on a distinguished road
Re: Drivers station problems
using LOLCODE will easily fix this problem for you
Unread 15-02-2009, 15:46
This means that the watchdog has gone hungry. You will need to feed it somewhere in your main loop or disable it.
OR did you mean that during the load process this happens? This is normal.
The LOLCODE thing is a joke, btw.
Unread 15-02-2009, 15:51
FRC #1647
No that happes after we deploy code.
Unread 16-02-2009, 09:16
FRC #1647
he is aware, he is on my team
Unread 16-02-2009, 09:42
drewDabb's Avatar
drewDabb drewDabb is offline
AKA: Drew
FRC #1089 (Mercury)
drewDabb is an unknown quantity at this point
Send a message via AIM to drewDabb Send a message via Yahoo to drewDabb
Are you using LabVIEW or the Workbench? I know my team is using LabVIEW and we had ourselves opening the watchdog twice which caused a similar error. After going through some of our subVIs we found the extra open and got rid of it, and now it works. I Hope that helps!
Unread 16-02-2009, 18:44
PinionTwister PinionTwister is offline
FRC #0269 (Cooney Tech)
PinionTwister is on a distinguished road
The watchdog must be fed!!! We had the same problem. We had the same wait time in all VIs in the Teleop code. We changed one of them to a faster time and then fed the Watchdog into that VI and the problem disappears.
Thanks to John Anderson for the help on this!
PS: We did not have the problem until we started using the control system at our practice session at Team 537 this past weekend. I suggest everyone check the watchdog in your teleop code.
Unread 16-02-2009, 19:36
blhenze blhenze is offline
Bernie H
FRC #2333 (Sapulpa Chieftain Robotics)
blhenze is an unknown quantity at this point
My programmers have gone AWOL and we are having the same problem. How do I find the watch dog and what should I check for?
Needless to say we're in a panic!!!!!!!!!!!!!
Can be contacted off line at bhenze@sapulpa.k12.ok.us
drivers station digital input trouble finman Electrical 9 16-02-2009 08:06
Drivers Station Magical Current 3DWolf Electrical 5 25-01-2009 21:52
Drivers' Station Camera Feed dhawk085 Technical Discussion 4 25-01-2009 19:12
Telling the drivers station your alliance Mike Mahar Technical Discussion 2 17-01-2009 12:24
Telling drivers station your alliance Mike Mahar FRC Control System 5 17-01-2009 08:43
