Go to Post the golden rule of robotics for the 21st century: Do unto robots as you would have them do unto you - KenWittlief [more]
Unread 15-02-2009, 14:37
hullingerbr hullingerbr is offline
FRC #1724 (Weber Fever)
hullingerbr is an unknown quantity at this point
Exclamation Potentiometer help
I am using potentiometers to program my steering and when I test the potentiometers I have to reset the program to recieve any new data. Could someone help me make it so that I constantly recieve input. I am using basic.
Unread 15-02-2009, 14:55
Chris1228 Chris1228 is offline
FRC #1228
Chris1228 will become famous soon enough
Re: Potentiometer help
basic labview?
Unread 15-02-2009, 14:56
Yeah, basic labview. Sorry to confuse.
Unread 15-02-2009, 15:52
FRC #1228
ok so wats your issue exactly? i didnt quite understand your problem
Unread 15-02-2009, 16:07
Okay, I have it so that it takes the input from the pot. Then it gets the voltage, then it displays the voltage. However, when I turn the pot, it doesn't register a change in voltage. Hopefully that clarifies it.
Unread 15-02-2009, 16:17
FRC #1228
is this all inside a while loop? can you post a copy of your code?
Unread 15-02-2009, 18:42
Oh, no. It wasn't in a while loop. That fixed the problem.
Dang, now the values are jumping all over the place
potentiometer programming help Chris1228 Programming 2 09-02-2008 21:30
Help wiring potentiometer-to-Analog port kylehager Electrical 4 17-01-2008 17:28
Potentiometer help Unholy Programming 4 07-02-2006 17:48
Potentiometer Help! thoughtful Programming 4 18-02-2005 08:21
Potentiometer Question, we need help! dez250 Electrical 13 25-08-2004 14:50
