Go to Post There are only 4 seasons of the year my friend, build season, competition season, post-season and pre-season. - Tom Schindler [more]
Unread 14-02-2009, 20:55
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Unhappy I need lots of help...please help
hey you guys this is tomy,
on valentines my team and i were working on programing we are meeting again on monday the day before shipment. is there anyone out there who can explain how to set up a spike in labview and were they get all of the components because i have looked at other threads and they make no sense i really really need help before i go insane. i just need a simple explanation on how to program in labview a spike and where you get the boxes with the yellow tops on them and how to hook everything up. i am a new programmer on a new team...i need help before i start throwing things...
p.s. if i still do not get this come time to competition i really hope there will be a nice team out there to come to my booth (team #3038) and help me please...
Unread 14-02-2009, 22:31
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
smcmahon is an unknown quantity at this point
Re: I need lots of help...please help
http://www.lvmastery.com/tipjar
If you've got a few hours, I'd recommend watching the videos above. I think you can find the Spikes in the WPI Robotics Library under "relays". You'll excuse me if I'm mistaken, I don't have LabView on this PC here at home. Either way, it's in the Robotics Library somewhere. Make sure you get the Open and the Close, and set the right channel for the spike in the code.
If you're going to be in Pittsburgh by any chance, we'd be happy to stop by.
Unread 14-02-2009, 22:57
i do not suppose anyone has pictures that would make it a lot eaiser
Unread 14-02-2009, 23:24
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
smcmahon is suggesting a video! Even better than still pictures! And with a live (ok, recorded) narrator!
Unread 15-02-2009, 00:03
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
To airnate you listen. Video is worth 1000 pictures.
Unread 15-02-2009, 11:02
yes but that website doesn't have anything on how to program a relay (spike)
Unread 15-02-2009, 12:26
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
Okay, right click in labview. GO down to where it says "WPI robotics library" then go to actuators. Then go to Relay. That's how you control spikes. Pic attached should help.
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 15-02-2009, 13:39
i know about that part can you please tell me the whole thing in one post step by step please. you can show it through using a joystick or by using the buttons
Unread 15-02-2009, 13:52
paulcd2000's Avatar
AKA: Paul Dagnelie
1. Open a relay.
2. Right click on the input that says Relay Channel, and go to where it says create. Then click constant.
3. Select the port for the relay in that constant
4. wire the Relay Dev Ref to a Set Relay block inside teleop (or autonomous, or somewhere else).
5. right click on the Set Relay block and create a constant where it says Relay Value (Same way as in step 2)
4. Select a direction for the relay.
Unread 15-02-2009, 16:07
okay now how do i set that up to use a joystick to control it or a joystick button
Unread 15-02-2009, 17:40
paulcd2000's Avatar
AKA: Paul Dagnelie
For a button:
1. Open a Joystick (WPI Robotics Library ->RobotDrive ->Joystick-> Open.vi)
2. Create constant, select joystick port.
3. Where you want the Relay to run, place Joystick Get (Same place)
4. Right click next to it and make an Unbundle by Name (Programming-> Cluster, Class,...->Unbundle By Name).
5. Wire the unbundle by name into where it says Buttons in the Get.
6. Select which button you want.
7. Wire the Boolean output of the button into a case structure.
8. In the "True" Case, put the Set Relay and set it to move (whatever direction you choose).
9. In the "False" Case, put another Set relay and set it to off.
ID:	7468  Click image for larger version
Unread 15-02-2009, 19:19
k that works for me but were to you get the "get buttons" blues box...?
Unread 15-02-2009, 19:33
Pausert Pausert is offline
FRC #1727 (REX)
Pausert is an unknown quantity at this point
From the joystick pallate, I believe. Unless you mean the constants, and then you right click on the node and choose "Create Constant".
Unread 15-02-2009, 21:10
okay thanks if i need more help i will let you know
PLEASE HELP!! Need help programming arm?? amirjpl Programming 12 15-03-2007 15:11
I need lots of help :ahh: germansamurai16 3D Animation and Competition 1 25-01-2007 23:21
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
