Go to Post ... You order Thunder Chicken Nuggets at the school lunch line - KelliV [more]
Unread 15-02-2009, 16:58
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Data delay between Crio and DS
Greg - thank you. At this point we tracked the issue down to the vision code. We took that out for now since we are working on the drive train and traction control today.
Once we try to add it back in, you can be sure I'll be contacting you
Thanks again!
cRIO Program Delay bomber7 Programming 2 29-01-2009 21:35
Capture Data from the cRio goodsky Programming 2 13-01-2009 21:27
EDU-MINI RC Solenoid Switching times and Delay time? Generalx5 Technical Discussion 0 25-01-2007 01:32
interference between wires and connectors Dan Zollman Inventor 5 18-12-2006 15:11
Delay in results and awards: drying out FRCOps Championship Event 0 01-05-2002 10:46
