Go to Post Then you might have a 1902 (oink oink BOOM) which could result in a 418 (Purple Haze). - JaneYoung [more]
Unread 15-02-2009, 11:36
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Data delay between Crio and DS
We are running the Crio from our computer in labview, currently there are major delays in drive values and other data between the robot and the joystick, about a one to two second delay. Is this normal, or is there something else slowing us down other than running off the computer?
Unread 15-02-2009, 12:33
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
Re: Data delay between Crio and DS
Running off the computer slows you way down, but one to two seconds is huge. Do you have any complex vision code? that can slow stuff down.
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 15-02-2009, 12:44
This sounds just like a behavior of the initial code. Have you updated the DS, cRIO, and you dev libraries to 3.0?
If this isn't it connect the serial cable from cRIO to a terminal program. That will tell a lot.
If there are lots of messages streaming to the serial, that will in fact cause this delay.
Greg McKaskle
Unread 15-02-2009, 12:52
Tom Line's Avatar
Greg, can we send you our code to take a look? We're really at a loss.
Unread 15-02-2009, 15:09
Sure. PM me I suppose.
Greg McKaskle
Unread 15-02-2009, 16:58
Tom Line's Avatar
Greg - thank you. At this point we tracked the issue down to the vision code. We took that out for now since we are working on the drive train and traction control today.
Once we try to add it back in, you can be sure I'll be contacting you
Thanks again!
Unread 15-02-2009, 17:47
Not seeing the code, my guess is that the vision code was placed directly into the tele loop. This will seriously delay processing tele packets that are streaming in at 50Hz.
Instead, try putting the camera code to run in parallel and update a global or local variable describing where the target is. Then incorporate that into your fast tele loop or you auto loop.
Greg McKaskle
Unread 16-02-2009, 18:03
PurpleHaze's Avatar
PurpleHaze PurpleHaze is offline
My friend Jeff is from Sweden
AKA: J.D. Iglesias
FRC #2219 (MegaHurts)
PurpleHaze is an unknown quantity at this point
We are having the same issue with delay. Our camera code causes the robot to have a delay with receiving inputs of about a second. It is running in its own parallel loop, and yet it affects the whole system. We've got less than 24 hours till we ship, and we need to get this up and running... Help?
Team MegaHurts 2219: If it ain't broken, wait a minute
Unread 16-02-2009, 22:59
Add a Delay VI inside your camera loop to keep it from running at full throttle. Suitably chosen, that delay will give the rest of your code a chance to run.
Unread 17-02-2009, 08:40
Tom Line's Avatar
Actually, we took the example labview code, copied it and pasted it directly into the vision processing .vi in the advanced framework. This caused a 1 to 2 second delay in everything we did.
We've got the next week or two to work with it since we held our controls system back (THANK YOU GDC), so we'll start working on getting the lead out of the routine on Friday.
cRIO Program Delay bomber7 Programming 2 29-01-2009 21:35
Capture Data from the cRio goodsky Programming 2 13-01-2009 21:27
EDU-MINI RC Solenoid Switching times and Delay time? Generalx5 Technical Discussion 0 25-01-2007 01:32
interference between wires and connectors Dan Zollman Inventor 5 18-12-2006 15:11
Delay in results and awards: drying out FRCOps Championship Event 0 01-05-2002 10:46
