Go to Post Who knew there were this many FRC teams that are teams! Very impressive, I might add. - [more]
Unread 15-02-2009, 19:13
Garii's Avatar
Garii Garii is offline
Registered Abuser
AKA: Jared Hankle
FRC #3044 (BE4)
Garii is an unknown quantity at this point
Send a message via AIM to Garii
Re: Missing Files?
When you say you corrected it by importing from the old_menus, directory, what do you mean? What steps did you take?
When the deployment fails, is there any other information? I don't remember for sure, but I thought there was a dialog left open that detailed the issues.
i found the ctl files i needed were in this directory. all i did was append the "menus" directory to "menu_broken" and renamed "menus_old" to "menus"
when the deployment failed i was unable to bring up any other info. it simply told me the deployed had failed. i searched for logs on it but didnt find any.
however the filename collisions you mented WERE an issue, but it seems that wasnt just it. I ignored the file name collisions and when i attemped to build i would get the error something similar to "C:\program files\... yada yada ...\menus\signal processing\somefile.ctl is missing" then it would suggest i replace forward slashes with backward slashes if im running OSX...Im not... so its a pretty useless suggestion. All i did was search my machine for the files and i found them in the "menus_old" directory
-The Garii- aka Jared Hankle
Ballston Spa Labview Programmer
new team slogan-"Can I Get Some Linux With These Fries?"
Inventor 10 files!!!! Dylan Gramlich General Forum 1 24-01-2007 20:03
Converting step files to inventor files GMAdan Inventor 4 01-01-2007 20:09
Missing files [527]phil Inventor 8 10-05-2006 10:20
STL files sanddrag Inventor 3 17-03-2005 15:38
CAD Help needed. Mech Desktop 6 files backwards to AutoCAD 14? (2d files) Elgin Clock Inventor 0 30-08-2004 23:06
