Go to Post I wouldn't mind dropping a banana peal or throwing a red turtle shell at other robots, but that's the rules! - SpaceOsc [more]
Unread 13-02-2009, 17:13
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Indicator light cables?
Does anybody know where we can get the Allen-Bradley indicator light cable that connects to the cRio. We haven't seen it in the KoP and are at a loss. It would be a huge help if you could tell us where we could get some.
Unread 13-02-2009, 17:17
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: Indicator light cables?
Check out the FIRST Power Distribution Diagram and use 22AWG wire. There is no pre-made cable in the kit. You can use a PWM cable.
It doesn't plug into the cRIO. It plugs into the RSL port on the Digital Sidecar. There's a little blinky light that should mirror the Allen Bradley light.
Russ
Unread 13-02-2009, 17:28
Thank You it helped a lot. When I read him the response he said what I know it goes the the RSL. So that was my bad and not his. Thank You again.
Unread 15-02-2009, 19:08
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Can you post the diagram to connect it? I guess we can connect all combinations but we didn't want to fry anything. Like, what do we do about the "N" slot? Which of the slots on the driver station do we connect to LA and LB?
Thanks,
Keehun
Team 2502
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 15-02-2009, 20:12
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
N is Ground, LA and LB are jumpered together.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 15-02-2009, 20:31
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
What we did is took one of the relay cables that you have in your kit, cut off one end then striped the wires. Works great.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 15-02-2009, 20:47
keehun's Avatar
Team Captain
AKA: Keehun Nam
Thanks! I ended up looking at the Data Connections on the FIRST control page
Crio network light does not light when camera plugged in Bongle Programming 16 16-01-2009 11:00
Lap Indicator Rule <R18> Clarification t-raum General Forum 1 28-01-2008 11:04
Multiple Light Tracking with Distinct Light Boxes in EasyC hal Programming 1 19-02-2007 11:56
DC Voltage indicator Don Wright General Forum 5 09-09-2005 07:52
OI indicator questions PyroPhin Technical Discussion 3 15-02-2002 08:53
