Go to Post If you cannot complete relatively simple tasks, why would anyone assign you something more challenging?? - Chris Fultz [more]
Unread 15-02-2009, 20:54
excel2474's Avatar
excel2474 excel2474 is offline
AKA: Aaron Stewart
FRC #2474 (Excel)
excel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the rough
Unhappy Simple Camera code HELP PLEASE?
I've spent hours reading and testing code to track the camera. I'm using windriver, and i'm not tying to do anything to complicated. I started with just compiling and downloading the example codes to the robot, but when I put the target in front of the camera, nothing happend. All I want to know, is how to find a color( green or pink or both) and if the camera sees it, turn on a motor. Can someone show me some commented code that will do this? Thanks a lot for the help because I'm desperate.
"Find some thing you like to do and EXCEL at it with dilligence."
University of Notre Dame- Mechanical Engineering.
Unread 15-02-2009, 21:22
Billfred's Avatar
Billfred Billfred is offline
Re: Simple Camera code HELP PLEASE?
For the record, I nudged this over to the WindRiver subforum to keep things orderly.
Unread 15-02-2009, 21:33
excel2474's Avatar
AKA: Aaron Stewart
FRC #2474 (Excel)
The problem with the subforums is that the post doesn't show on the portal page. At least that was my experience.
Unread 15-02-2009, 21:51
Billfred's Avatar
That happens when forums get added--they don't get added to the portal lists by default. Click "Config" on the top of that list and it can be made to show.
Unread 16-02-2009, 00:22
I'd say the vision example code is probably the most likely to work out of the box as anything. Next step is to put some print statements where the object center is found to try and determine if it is a watchdog, electrical, or code issue.
Greg McKaskle
Unread 16-02-2009, 10:11
excel2474's Avatar
AKA: Aaron Stewart
FRC #2474 (Excel)
Greg McKaskle
OK, where is the printf displayed at. I couldn't figure this out.
Unread 16-02-2009, 19:42
I haven't used WindRiver in a long time. I think there are two possible locations. The low level one is the terminal program hooked to the serial port. I think you can also open a terminal over enet in the Eclipse environment. Sorry, but I can't give you any details on that one.
Greg McKaskle
Unread 16-02-2009, 21:48
dboisvert dboisvert is offline
AKA: Dan Boisvert
FRC #2405 (Divided by Zero)
dboisvert is an unknown quantity at this point
You can do it remotely by going connecting to the cRIO in the bottom left corner of the Remote Systems and after that right click "Wind River Target Debugger" go to > Target Tools > Target console.
A dialog box should open up, click ok and then you should see your printouts. They come rather quickly so be prepared for it.
Please help me with my Camera problems! Ianuser Programming 2 10-02-2007 21:17
Camera Code Help Please The yellowdart Programming 1 10-02-2007 15:45
please help me to plag in the camera CompMaster Programming 1 16-02-2006 11:24
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
