Go to Post First and foremost, teach which end is the hot one on a soldering iron. - Al Skierkiewicz [more]
View Poll Results: How far have you gotten on coding the camera tracking?
Completed 25 22.73%
Debugging 29 26.36%
Work in progress 31 28.18%
Just started 10 9.09%
Havent started 10 9.09%
Not going to use the camera for that 5 4.55%
Voters: 110. You may not vote on this poll
Unread 12-02-2009, 18:53
s0crates s0crates is offline
s0crates is on a distinguished road
Re: How far have you gotten on coding the camera tracking?
Originally Posted by Dr. Manhattan View Post
We tried testing it with the full range of color available, yet for some reason the green doesn't show up at all. So far I have no clue why. And for some reason the servo's aren't moving while on gimble tracking mode, I assume they're supposed to and have no clue why.
And yes, see you there.
The way I did it when it absolutely failed to pick anything up was to start with the range 0-255 for all 3 (hue, saturation, and luminance) and narrow it down from there. Slow, but it works.
Did you put the jumpers next to the servo pwms? Are the pwms in the program the correct ones/where the servos are plugged in?
-jonathan
Unread 12-02-2009, 19:00
If you aren't having any luck with the colors, you might try the NI Vision assistant. It is an easy way to bring in an image and check out the pixels in HSL. Ideally, you get in the habit of grabbing a couple photos in different orientations, different amounts of light, etc. Then you get a better feel for the range of HSL values needed to cover the different lighting.
Greg McKaskle
Unread 12-02-2009, 20:19
Dr. Manhattan Dr. Manhattan is offline
Atomic Reconstruction
AKA: Joe Bakke
FRC #2521
Dr. Manhattan is on a distinguished road
Send a message via AIM to Dr. Manhattan
-jonathan
Yes, I know that the pwm's are correct because we have code to be able to control them with a joystick on the same pwm channels. I'm checking it out now and seeing if we can get it to work, but a lot of our focus is on the encoders at this point in time.
Unread 15-02-2009, 21:01
mikeqfl's Avatar
mikeqfl mikeqfl is offline
FRC #0832 (Chimera)
mikeqfl is an unknown quantity at this point
We have our camera tracking ok. It commands a motor to turn a turret to keep the image in the center of its field of view. The problem we are having is the camera/turret is constantly oscillating back and forth trying to find the center. Any ideas of how to put in a PID loop into Labveiw? I am not up on the programming, just trying to help our programmer out.
Unread 16-02-2009, 01:44
It sounds like it would be easiest for you to just have a dead zone in the center of the image - if the target is within a certain bounding box in the center of the image don't try to adjust it any further. Rather than try to center it at the center pixel, aim for a box around the center. It oscillates because the image changes slightly frame-to-frame.
Unread 17-03-2009, 23:18
cooldude8181's Avatar
cooldude8181 cooldude8181 is offline
AKA: Charlie Davies
FRC #1245 (Shazbots)
cooldude8181 is an unknown quantity at this point
It took us a very long time to finally get it to the point that it worked, but we do have it working...
Unread 18-03-2009, 17:17
Lord_Jeremy's Avatar
Lord_Jeremy Lord_Jeremy is offline
Lord_Jeremy the Procrastinator
AKA: Jeremy Agostino
FRC #1546 (Chaos Inc.)
Team Role: Electrical
Lord_Jeremy is an unknown quantity at this point
Send a message via ICQ to Lord_Jeremy Send a message via AIM to Lord_Jeremy Send a message via MSN to Lord_Jeremy Send a message via Yahoo to Lord_Jeremy
We ran into some pretty massive problems. No matter what we seemed to do, the camera would intermittently find a color (or two) for a few seconds, then x and y would immediately go to maximum. We assumed it was centering on the fluorescent lights in the room, but we're not entirely sure. And it was doing this both with our code and the TwoColorTrackingDemo code. I don't think the camera was at fault, as images grabbed from it looked just fine. We tried manually defining the color fields a couple times but that didn't help. Mind you we're using C/Windriver.
Compiling...
Compiling...
Unread 18-03-2009, 22:56
jacobhurwitz jacobhurwitz is offline
FRC #0449 (Blair Robot Project)
jacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura about
We've spent a long time on our camera tracking code, and it finally works very well! (The night before our regional, too. Phew!) Our robot has a shooter, and we're using the camera to aim it at targets and then calculate how far it should fire. I'm pretty sure we'll post all our code on CD at the end of competition season, in case anybody's interested. We also have a pretty cool dashboard
how far have you gotten on your robot? gondorf General Forum 167 26-01-2010 07:35
How far have you gotten in "100 Bottles of Milk on the Wall"... Billfred Chit-Chat 25 29-03-2009 18:01
How far has your team gotten? Alex Burman Chairman's Award 5 21-01-2006 15:43
Have you gotten your robot to go towards the vision tetra? Bharat Nain Programming 20 25-02-2005 20:18
So how much have you all accomplished so far? team222badbrad General Forum 16 16-01-2002 18:09
