Go to Post First check for any bind in the transmissions, especially chain. Next, check to see if the motors are O.K. Use code as a last resort. - Paul Copioli [more]
Unread 15-02-2009, 22:12
PWHSrobotics PWHSrobotics is offline
PWHSrobotics is an unknown quantity at this point
Building Program with Gyro
I am going from the project Explorer
Build Specifications -> FRC Basic Robot Deployment-> Properties
then I used Preview before I chose to build my robot's code., only one problem I got an error:
LabVIEW cannot find a file that is a dependency of a Startup, Exported, or Always Included VI.
File Not Found: C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\Robotics Library\WPI\Gyro\GyroDevRefToAnalogChannelDevRef.v i
The thing is, I navigate to folder, and that VI is just sitting there where it says it is not. Anyone else have a problem like this? Plz help, not a lot of time to finalize this.
Unread 15-02-2009, 23:58
Re: Building Program with Gyro
I think that problem was introduced in the 3.0 update to LabVIEW, and didn't get fixed in the 3.0a update. When you actually Build the project, LabVIEW will not find the VI on its own, and it will give you an Open File dialog for you to find the VI for it. Once you have navigated to and selected the file, LabVIEW should be happy (for that project, anyway).
Unread 16-02-2009, 00:36
well, the first time I placed a Gyro 'close' vi, it couldn't' find it and I manually found it. and then it worked after that till now with the build. I am almost certain the url that it says it can't find it at (which it is there) is teh same I led it to when I initially dropped the close vi.
Unread 16-02-2009, 00:59
url = path
Building self balancing scooter- troubles with Integrating Gyro gohan22 Sensors 8 22-01-2009 23:06
Problem with gyro... capenga Programming 21 16-02-2006 19:25
Building a (FIRST) Robotics Program in the Community craigbutcher Team Organization 1 26-04-2005 11:02
Building a Clock with Periodic Motion IMDWalrus Math and Science 15 24-03-2004 16:48
