Go to Post hiring a monkey may not be a good idea i used that method once and it cost me a fried motherboard... - Cuog [more]
Unread 15-02-2009, 22:57
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
Re: Problems with using 330's goal tracking code
how do you put time values for the x variable each iteration? I guess I could just put a counter that increments, but im not sure how to do this either. I would like to not use a for loop. Any suggestions?
Unread 16-02-2009, 13:02
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
Sorry, I assumed you wanted an XY plot (plotting one variable against another). If you have two independent variables to plot, then use a Chart.
Bundle the two values (presumably X and Y) together and then wire to the Chart terminal.
Problems with tracking Shinsa Programming 2 07-02-2010 14:35
Using kevin's code for driving and camera tracking razzoc Programming 3 18-02-2007 08:50
Enabling Multiple Light Tracking Using Kevin's Code Mitch Programming 7 05-02-2007 06:17
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Problems tracking with CMUCam2 in LabVIEW PhilBot LabView and Data Acquisition 5 17-01-2006 20:42
