Go to Post Just be nice. It works better in the long run. - Libby K [more]
Unread 15-02-2009, 11:43
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
How does the trailer affect your driving???
When we finally started to drive our robot around i thought hey we were going to be pretty fast, and mobile. I give my self a pat on the back here (i am head of power train design). but then we attach the trailer. We seem to be a lot slower, this was expected to some degree (pulling 40 pounds around tends to do that) . but the thing that has me worried is while we can make really sharp turns it is really slow and normal wide turns are hard to use when aiming. i just want to know is this common with other bots or is it just us???
we have a 4 wheel independent tank style drive train with traction control.
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
Unread 15-02-2009, 11:45
Phoenix Spud's Avatar
Phoenix Spud Phoenix Spud is offline
Everyone. Everywhere.
FRC #3132 (Thunder Down Under)
Phoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond repute
Re: How does the trailer affect your driving???
Yes we have found the same thing with tank drive.
Sarah Heimlich
Outreach Mentor | Business Mentor
FIRST® TEAM 3132
Unread 15-02-2009, 13:33
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
When I drive the bot without the trailer I find it a lot easier than without. Yes it does slow us down substantially but it also adds some stability among other things. The trick I found it to always keep the trailer moving and use it like a counterweight to help you turn and other things. Also when changing directions (backwards to forwards) you can use the trailer as a point of rotation and do a 180 if you stay on the sticks right.
Btw, We have a wide base 6wd. (similar to a wide base 4wd)
-Dustin Benedict
Unread 15-02-2009, 13:37
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
the only problem I noticed is starting from a stop,although that is solved with our traction control
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 15-02-2009, 13:51
ZInventor's Avatar
ZInventor ZInventor is offline
AKA: Zeno Le Héricy
FRC #2915 (Riverdale Robotics Pandamonium)
ZInventor is just really niceZInventor is just really niceZInventor is just really niceZInventor is just really nice
I'm the primary driver for our team, and we just had a scrimmage yesterday.
It taught us a lot, like, if you want to turn really sharp, you can't. the closest we got was starting a sharp turn, then pushing the joystick forward a bit.
we have a 4wd NARROW base, skid-steer chassis, and it seems like that was a bad idea, as it seems a lot harder to turn.
even so, the regolith impaired everyone a lot more than they expected, and even the big, wide-base bots were really easy to push around (it seems like wide bases turn better, but narrow bases push a lot better.
we also saw a lot of shooters die. they seemed to completely loose accuracy once the bands in the balls started breaking (by the end of the first scrimmage match [on a half field, only 3 bots] EVERY ball had at least one band broken, and by the end of the third match, most had 2 or 3 broken)
another thing we noticed, was that shooters seemed to jam alot if the bands in the balls broke.
just my $.02...
-Z
[center]
Unread 15-02-2009, 13:55
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We've been using broken balls for testing our robot, so we're pretty well used to the broken ball jamming/shooting problems. We've gotten our robot to work well with balls with only 1 or 2 broken bands, but when they get 4 or more they start to cause problems.
Having the trailer seems to affect our driving on the FRP in an interesting way...we only have 3 sheets, and only enough carpet for that much, so we can't even turn the robot around on the FRP with the trailer on it (our test area is 8 x 12 feet). I guess our driver will learn a lot Thursday of our first regional!
Unread 15-02-2009, 14:02
ZInventor's Avatar
AKA: Zeno Le Héricy
ma favorite way to turn is to put the robot in full speed reverse, jacknife the trailer, and watch it slingshot the robot around. once the bot gets to the halfway point of the turn, throw it into full forward (bad for the cims i know... ) but, EXTREMELY effective for turning really fast, and getting away...
at the scrimmage, most shooters were having troubble getting more than a coupple balls in another trailer in a row.
however, our team has a dumping robot, and our reckord was getting 6 balls into another trailer at once ***(beu, er failed at repeating it...)
on average, we got 3 or 4 balls in each time we dumped...
-Z
[center]
Unread 16-02-2009, 00:14
Chris is me's Avatar
AKA: Pinecone
This has been my experience with tank drive with programmed traction control limiting acceleration. An important thing to note is to practice backing up with a trailer. The trailer will go the opposite way you initially back up (as it does on a car), so you need to account for that when driving.
Unread 16-02-2009, 00:18
GillSt.Bernards's Avatar
GillSt.Bernards GillSt.Bernards is offline
AKA: Amanda Cullen
FRC #2458 (Team Chaos)
GillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to all
Send a message via AIM to GillSt.Bernards
The first time putting the trailer on the robot it was so much harder to drive. We were in the court yard of one of our buildings and our driver actually did not feel comfortable driving thinking that he might break a window. (the building is surrounded by windows) It affected our driving a lot
"A Dream is just a dream, a goal is a plan with a deadline" - Fortune Cookie-
"Life is a runaway train you can't wait to jump on"
-Sugarland (Already Gone)-
Unread 16-02-2009, 00:21
Parks60 Parks60 is offline
AKA: Jared Parks
FRC #0060 (Bionic Bulldogs)
Team Role: Electrical
Parks60 is an unknown quantity at this point
yea we used last years robot ("lappy") to test our trailer and it did slow him down a bit but it wasn't to bad, our turns are alil hard to do though =/ other than that everything seemed normal
electrical and programming for team 60 =)
Unread 16-02-2009, 00:42
GBIT's Avatar
GBIT GBIT is offline
Lexantologist/Team Lead
AKA: Jared
FRC #0811 (Cardinals)
GBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really nice
Send a message via AIM to GBIT
We noticed that is did slow us down but we use all driver skill to get the bot moving without slippage
-Mentor-
-WPI '13-
-Former Team Lead-
-Past Driver-
Unread 16-02-2009, 00:48
1t5h1e1o's Avatar
1t5h1e1o 1t5h1e1o is offline
Das boot.
AKA: Theo Matt
FRC #1511 (Rolling Thunder)
1t5h1e1o is a jewel in the rough1t5h1e1o is a jewel in the rough1t5h1e1o is a jewel in the rough
Send a message via AIM to 1t5h1e1o
With about half a field's worth of Regolith so far for the Rochester Rally tomorrow (ha actually today now , and finally fixing our belt problem, I can only say that this is the most fun driving that I have ever had. We have a 4 wheel, wide base, tank drive, and the trailer actually seems to make turns easier. I am able to make pretty sharp turns, and I can actually still do burnouts quite fast. Once you get the hang of using the weight and force of the trailer to whip your robot around turns, you'll see what I mean. Its awesome!
2010 FLR Engineering Inspiration Winner, 2010 Boston Chairman's & Coopertition Winners!
2009 FLR Entrepreneurship Winner; 2009 Chesapeake Website, Imagery, & Chairman's Winners!!!!
2008 FLR Engineering Inspiration Winner; 2008 Philly Safety & Imagery Winners
2007 FLR Chairman's Winner!!! 2007 Boston Spirit & Website Winners
Record on the Field: (2008-2010) 61-45-3
Unread 16-02-2009, 00:55
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
So far, for us the biggest issue with the trailer hasn't been slippage(he have an accelerometer-based TC system that handles that pretty well), but its impact on driving backwards. Our plan is to use a gyro to compare ideal versus actual heading and corect accordingly, but we're having trouble integrating it with the tank drive
Get yer robot source code here!
Unread 16-02-2009, 09:51
nahstobor's Avatar
nahstobor nahstobor is offline
EWCP
AKA: Shan (pronounced Shawn)
FRC #2733 (Pigmice), FRC #612 (Chantilly Robotics)
nahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond repute
612 is using front wheel steering on our robot and it has improved our driving abilities with the trailer a lot as opposed to using tank drive. It is really interesting because robots don't have the ability to turn on a dime anymore. So it some ways it plays to our advantage when we are trying to anticipate another robots movement when we are trying to score and hurts us when others are scoring on us. But it is a lot of fun to see that robot drifting all around the field.
Does CD affect alliance selections? XaulZan11 General Forum 21 14-04-2008 22:51
Does a School Closing affect your progress during build season? 65_Xero_Huskie General Forum 77 15-02-2007 10:59
How does your team travel to the championship? Alex Burman Championship Event 41 24-04-2006 21:28
How does your team spend the Kickoff afternoon? Billfred Rules/Strategy 43 08-01-2006 03:33
