Go to Post Now if MTV had an episode of "Made" where the school's top jock wanted to drive a FIRST's teams robot to victory...now that would be a good one. - Koko Ed [more]
Unread 16-02-2009, 00:45
koo_04 koo_04 is offline
FRC #2493
koo_04 will become famous soon enough
Problems with the newest updates...
So we decited to update the cRIO, DS, and LabVIEW. Well, we have had nothing but problems since. We keep getting the blinking light on the Digital side car. We have elimanated the Watchdog itself problem and the DS is updated correctly. We don't know if the cRIO is though... the update went really quick and puzzled us if it was supposed to go so fast. Please help, we are starting to get really frustrated
Unread 16-02-2009, 00:55
Re: Problems with the newest updates...
The reimage of the cRIO should be fifteen minutes or so. Do again, and make sure to check the box to format it.
Greg McKaskle
rsisk's Avatar
rsisk rsisk is online now
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Update:
The DS displays
System : Watchdog
when the code is deployed. Have followed the diagnostic steps from the NI website: http://decibel.ni.com/content/docs/DOC-2957
The RSL on the Digitial Side car has a slow blink
The versions on the DS is 2009-02-10a3
The version of Labview is 3.0a
The Imaging tool shows FRC_2009_v11.Zip but as Doug say, cannot confirm that is actually running on the cRIO
Unread 16-02-2009, 00:56
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
OK, will give that a try Greg, back to you in about 15 minutes.
Any idea how to confirm the version of the image on the cRIO once the update is done?
Unread 16-02-2009, 01:09
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
Success! Thanks.
Clicking on "Reformat" when loading the cRIO update made it work.
Thanks Greg.
Problems with the connections to the Keyang motor nofar#1943 General Forum 2 01-02-2009 19:27
PROBLEMS WITH THE CAMERA RDD Programming 2 18-02-2007 15:12
Problems with the manual of the green target (for cmu cam) Kawashima Kit & Additional Hardware 1 28-01-2007 13:31
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
