Go to Post I have some free time tonight (What?) - Brandon Martus [more]
Unread 15-02-2009, 20:12
coolperson987 coolperson987 is offline
FRC #1798
coolperson987 is infamous around these partscoolperson987 is infamous around these parts
CAN I USE THIS
Hello, i want to use this banebot motor; this is the link:
http://banebots.com/p/MP-36064-540
Unread 16-02-2009, 07:52
GaryVoshol's Avatar
Cogito ergo arbitro
Re: CAN I USE THIS
Did it come in the Kit of Parts? Is it an exact replacement for one of the motors in the kit that got damaged?
If not, you can't use it. See <R50>, <R51> and <R52>.
(since 2004)
Unread 16-02-2009, 09:44
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: CAN I USE THIS
YOu can use the gearbox, but you have to take the motor part off of it, and replace it with a kit motor. You should buy some extra pinion gears so you can just put a new pinion gear on the kit motor, instead of having to try to remove the gear from the motor that you can't use.
We used that gearbox on this years robot by changing to a kit motor, it works fine for turning our turret. We have a V belt drive, so it can slip, which is an important safety feature to keep from burning up the motor, since our programmers have been very challenged trying to get the limit switches working.
Unread 16-02-2009, 10:34
Donut Donut is online now
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: CAN I USE THIS
You can use that transmission, but you must exchange the motor for a kit one (both the RS-545 and the Fisher Price motors can be put into it without much difficulty).
If you have to order this and won't be putting it on until your regional I would recommend this instead:
http://banebots.com/pc/P60K-nnnn/P60K-444-0004
It is the same reduction but is a newer transmission with a more durable construction, and it ships with an RS-545 meaning the motor it comes with IS legal for use. We're using 2 of these for our drive system right now and have had no problems thus far (we put fans on it for cooling, which I would recommend if you'll be demanding alot from these motors).
Unread 16-02-2009, 10:40
MrForbes's Avatar
AKA: Jim
Re: CAN I USE THIS
Technically it's not legal for use until you burn up the two motors that came in the Kit of Parts.....then you can use it to replace them.
Unread 16-02-2009, 11:28
Alex698's Avatar
Alex698 Alex698 is offline
Sparky
FRC #2449 (Out of Orbit Robotics)
Alex698 is a jewel in the roughAlex698 is a jewel in the roughAlex698 is a jewel in the rough
Send a message via AIM to Alex698
Re: CAN I USE THIS
According to the linked banebots page, it shows a RS-540 shipped, not a RS-545 motor, so the base configuration is illegal.
Eat, Sleep, Build Robots
Unread 17-02-2009, 02:23
The Arizona Mentor
AKA: Andrew
Re: CAN I USE THIS
This is true for the 36mm transmission but not for the P60 gearbox I linked to in my post. As long as you check the "ship with RS-545" box you get them with the P60's.
Unread 17-02-2009, 21:22
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
Re: CAN I USE THIS
Where does it say the KOP motors have to have died before you can use exact replacements? There is no theoretical advantage to using a replacement motor for the KOP one (except maybe that it's got less wear on it), so there is no power advantage, which is the stated intent of the motor restriction rules.
Unread 17-02-2009, 21:32
MrForbes's Avatar
AKA: Jim
Re: CAN I USE THIS
It says so in the rules. I don't make up the rules, I just try to follow them.
<R51> Motors specifically permitted on 2009 FRC ROBOTS include:
E. COTS motors used as one-to-one replacements (i.e. identical vendor and
part number) for motors, actuators and servos provided in the 2009 Kit Of
Parts that may have failed or become inoperable.
Unread 17-02-2009, 21:38
ZInventor's Avatar
ZInventor ZInventor is offline
AKA: Zeno Le Héricy
FRC #2915 (Riverdale Robotics Pandamonium)
ZInventor is just really niceZInventor is just really niceZInventor is just really niceZInventor is just really nice
Re: CAN I USE THIS
then burn out the kop motors, and buy the new grarboxes.
oops, that's un-gp though...
well, the judges won't know you still have the old kop motors, plus, as it has been said before, what's the gain in forcing teams to use the kop motors first?
-Z
[center]
Unread 17-02-2009, 21:40
MrForbes's Avatar
AKA: Jim
Re: CAN I USE THIS
Now that you mention it, the rules don't specify how the motors "become inoperable"...it could be that they met an ugly fate involving a large hammer
Unread 17-02-2009, 21:43
ZInventor's Avatar
AKA: Zeno Le Héricy
Re: CAN I USE THIS
oops, you mean motors aren't meant to go in the 100 ton press-brake?
dang.
-Z
[center]
Unread 17-02-2009, 21:53
Re: CAN I USE THIS
squirrel, if older, same part# small CIMs can be subbed in without the new ones being obtained new, then I would assume that the BB motors of the right type can also be. It's a one-to-one replacement, as in, if for any reason, you don't like a motor, you can substitute another motor of the same type (or rather, part number).
I'm not on the GDC, though, and this is also not the official Q&A.
Unread 17-02-2009, 22:03
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Re: CAN I USE THIS
It's not that hard to smoke these motors anyway. If you really want to follow the letter of the rules, just take the plain motor, and clamp both the motor and shaft so neither can rotate. Power until smoke results.
Unread 17-02-2009, 22:06
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Re: CAN I USE THIS
It's even easier to remove the motor from the garbox and put the one from the kit in
which gearboxes can we use for this year? mahmosh Kit & Additional Hardware 2 09-01-2009 19:52
Can you use this? Mars Control System 7 23-01-2008 08:24
I can read this....can you? Wayne Doenges Chit-Chat 2 22-03-2006 14:49
Can we use the 2005 RC for this year's robot? DemonYawgmoth Control System 6 13-02-2006 17:34
Can we use? Team537 General Forum 2 29-01-2002 16:49
