Go to Post Don't you just wish life had a redo button? - DHarris [more]
Thread Tools Rating: Thread Rating: 75 votes, 5.00 average. Display Modes
Unread 02-16-2009, 08:17 AM
Mr. Lim Mr. Lim is online now
AKA: Mr. Lim
Re: WPILib PID controller object
Originally Posted by sircedric4 View Post
void CamSource :: SetSource (double sourcedum)
	source = sourcedum;
double CamSource :: PIDGet()
	return source;
We've done pretty much exactly the same thing as you did here. I think we're running into a small concurrency problem though, and would like to hear from you as well.
As once in a blue moon your camera "spaz" while it is tracking?
Very rarely, but often enough to make it a pain, our camera tracker will move out of position quickly then recover for no apparent reason.
I think it's because of a classic concurrency issue where source is being read and written at the same time.
The PID controller runs in a separate task, and so potentially both SetSource and PIDGet could be called at the same time.
Would any more experienced programmers out there recommend locks? And if so, how would you implement them in the quoted code?
In life, what you give, you keep. What you fail to give, you lose forever...
void* pointer to object in C++ byteit101 C/C++ 6 01-14-2009 05:15 PM
UI Board Object Specs 3DWolf Control System 2 12-10-2008 04:13 PM
Demo: Simple robot arm with a PID controller mtomczak Programming 1 01-17-2008 02:17 AM
rangefinding/object detection sciguy125 Electrical 14 01-13-2008 08:36 PM
Object Enablers SherryG Inventor 1 04-07-2006 10:01 AM
