Go to Post it's called the Mars Rock automode (you sit there and wait for Opportunity to come along). - EricH [more]
Thread Tools Rating: Thread Rating: 75 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 16-02-2009, 08:59
Kruuzr Kruuzr is offline
Mentor - electrical, software
AKA: Steve Cote
FRC #1922 (Ozram)
Kruuzr has a spectacular aura aboutKruuzr has a spectacular aura about
Re: WPILib PID controller object
Originally Posted by SlimBoJones View Post
We've done pretty much exactly the same thing as you did here. I think we're running into a small concurrency problem though, and would like to hear from you as well.
As once in a blue moon your camera "spaz" while it is tracking?
Very rarely, but often enough to make it a pain, our camera tracker will move out of position quickly then recover for no apparent reason.
I think it's because of a classic concurrency issue where source is being read and written at the same time.
The PID controller runs in a separate task, and so potentially both SetSource and PIDGet could be called at the same time.
Would any more experienced programmers out there recommend locks? And if so, how would you implement them in the quoted code?
If your code in SetSource consists of just an assignment statement, it's probably not a concurrency issue. Although it's poor style to not protect it with a semaphore, a simple assignment of an int or float is usually what's called an 'atomic' operation, which means that it would not be interrupted in the middle by a task switch. (It happens in one machine language operation) I would look elsewhere for the cause.
If you have more than one line in SetSource (or if you want to get used to how to do multithreaded programming) you need to protect the function with a semaphore. The 'C programming guide for FRC.pdf' page 78 discusses how to do this. It's not hard, just a matter of adding a line at the beginning and end of your function.
Steve C
void* pointer to object in C++ byteit101 C/C++ 6 14-01-2009 17:15
UI Board Object Specs 3DWolf Control System 2 10-12-2008 16:13
Demo: Simple robot arm with a PID controller mtomczak Programming 1 17-01-2008 02:17
rangefinding/object detection sciguy125 Electrical 14 13-01-2008 20:36
Object Enablers SherryG Inventor 1 07-04-2006 10:01
