Re: Update #12 - software/firmware
What about the WPI?
Yes. Listed in Update #12 are 4 things we need to make sure are updated:
Software/Firmware Revision Labview for FRC Update 3.0a and newer cRIO FPGA Image FRC_2009_v11.zip and newer WPI Robotics Library 3.0.1718 and newer Driver Station 2009-02-010a3 and newer These were updated in Update #12 (the ones in RED) Last edited by chinckley : 16-02-2009 at 15:38. Reason: color |
When I clicked the above link it said C/C++. We did update the DS last night and it worked. I see the correct Labview update we did. How do I tell if I have cRIO FPGA Image FRC_2009_v11.zip and newer? If I need it where do i GET IT? Do we do all these things: Came from above link. Downloads Workbench Updater: WorkbenchUpdate 3.0.1718.exe (19Mb) Source code for vRC0.1718: WPILibRC0.1718SourceCode.zip (372kb) (remember that this will only work with the FRC_2009_v11.zip cRIO image, below or with LabVIEW update) cRIO Image updater (stand-alone without LabVIEW) - FRCNIWRUpdate3.0.a.zip (90.5 Mb) Documentation - also located in c:\windriver\docs\extensions\FRC after the installation - FRC1718Docs.zip (17 Mb) C++ Reference as a Windows Help file with hyperlinked class diagrams C++ PDF Reference document C PDF Reference document FRC Vision Windows Help File FRC Vision API Specification Thanks Last edited by chinckley : 17-02-2009 at 09:12. Reason: added text |
You only need to update WPILib if you are programming in C/C++
#7
Another major change is the no wireless except on the competition field.
This means tethered in the pits and on the practice fields. Make sure you have access to the ethernet port on the cRIO. We had to move ours to make it easier to plug/unplug as we came back to the pits at Suffield Shakedown. So now I go off to buy a long ethernet cable for practice. |
#8
Thank you so very much.
| Update 11 | EricH | General Forum | 27 | 23-02-2008 17:31 |
| Update #19 | GBIT | General Forum | 24 | 30-03-2007 09:15 |
| Update #8 | Nita | General Forum | 0 | 10-02-2006 23:51 |
| Update 6 | archiver | 2001 | 1 | 24-06-2002 00:24 |
