Go to Post Above all, have fun and, if you need help, ask for it... Your inspectors will be glad to help or try to arrange for another team to help you. This should not be a traumatic experience! - Mike Betts [more]
Unread 16-02-2009, 11:35
TDohse TDohse is offline
AKA: Thomas
no team (NI)
TDohse is an unknown quantity at this point
Re: How to check versions
If you FTP to your cRIO, there is a file named FRC_ImageVersion.txt which shows image version, date, FPGA version, and NetComm version. If your cRIO doesn't have that file, it most likely means you have an old image on the device (earlier images lacked that file).
A second method of determining if your cRIO is up to date, is to watch the console output when the device boots. If you have FRC_2009_v11.zip on the cRIO, you will see this output:
FRC_NetworkCommunication was compiled from SVN revision 1712
FPGA Hardware GUID: 0x6F0EA7B88ADB8E3FD4127A39E3502C6D
FPGA Software GUID: 0x6F0EA7B88ADB8E3FD4127A39E3502C6D
FPGA Hardware Version: 2009
FPGA Software Version: 2009
FPGA Hardware Revision: 1.0.0
FPGA Software Revision: 1.0.0
Brecoflex Belt Versions JasonS Technical Discussion 13 02-02-2006 01:13
AMD or Pentium, Laptop Versions lndnny Chit-Chat 6 06-12-2005 00:12
Old versions folder oljomo Inventor 2 11-03-2005 23:11
3 Versions of X-Box 2? Raven_Writer Chit-Chat 4 14-11-2004 13:33
WDW Park Hopper Passes-How to check joe_balint General Forum 19 21-05-2002 16:28
