Go to Post Or you can always say "we programmed it that way." - probizzle [more]
Unread 16-02-2009, 00:01
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
How to check versions
Could someone detail the correct steps to check the version of the code on the:
cRIO
Driver Station
LabView on the laptop
And then post what is the correct verions we should have.
Thanks!
Unread 16-02-2009, 00:03
Re: How to check versions
Thanks!
Update #12 already did that. I think someone posted the process, but I don't remember where.
Unread 16-02-2009, 00:34
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
Thanks Eric, didn't realize the versions were in Update 12. They are copied below for convenience...
LabVIEW for FRC Update 3.0a and newer
cRIO FPGA Image FRC_2009_v11.Zip and newer
WPI Robotics Library 3.0.1718 and newer
Driver Station 2009-02-010a3 and newer
So far I have figured out these steps to obtain versions, but I am having a tough time getting the cRIO version. I know the imaging software shows FRC_2009_v11.zip, but I am not sure that is what is actually on the cRIO.
DS version is on the display as "DS Rev : 2009-02-10a3"
Labview version, click on Help/About First Robotics..., should be 3.0a or higher
Tried searching CD, but couldn't find a link to the answer.
Unread 16-02-2009, 11:35
TDohse TDohse is offline
AKA: Thomas
no team (NI)
TDohse is an unknown quantity at this point
If you FTP to your cRIO, there is a file named FRC_ImageVersion.txt which shows image version, date, FPGA version, and NetComm version. If your cRIO doesn't have that file, it most likely means you have an old image on the device (earlier images lacked that file).
A second method of determining if your cRIO is up to date, is to watch the console output when the device boots. If you have FRC_2009_v11.zip on the cRIO, you will see this output:
FRC_NetworkCommunication was compiled from SVN revision 1712
FPGA Hardware GUID: 0x6F0EA7B88ADB8E3FD4127A39E3502C6D
FPGA Software GUID: 0x6F0EA7B88ADB8E3FD4127A39E3502C6D
FPGA Hardware Version: 2009
FPGA Software Version: 2009
FPGA Hardware Revision: 1.0.0
FPGA Software Revision: 1.0.0
Brecoflex Belt Versions JasonS Technical Discussion 13 02-02-2006 01:13
AMD or Pentium, Laptop Versions lndnny Chit-Chat 6 06-12-2005 00:12
Old versions folder oljomo Inventor 2 11-03-2005 23:11
3 Versions of X-Box 2? Raven_Writer Chit-Chat 4 14-11-2004 13:33
WDW Park Hopper Passes-How to check joe_balint General Forum 19 21-05-2002 16:28
