My servos lock up just thinking of you
Unread 16-02-2009, 12:27
Re: need help with compressor code
Along with your code, please describe in detail how you have the compressor and pressure switch electrically connected to the control system. There are half a dozen ways to get it subtly wrong, and any number of ways to do it completely wrong.
Unread 16-02-2009, 12:49
T3H_K3YM45T3R's Avatar
T3H_K3YM45T3R T3H_K3YM45T3R is offline
AKA: Christopher Robinson
FRC #1737 (Project X)
T3H_K3YM45T3R is an unknown quantity at this point
here is a link to an image of the code, sorry it's a link and not an attachment, it was the fastest way for me to get the whole thing up.
http://www.firstwiki.net/media/2/2d/1737_robot_code.jpg
now for the way we have the compressor and relay electrically connected: we have the main power connected to the "12v" side and the output is hooked up to the m+ and m- side of the spike. the pwm cable is plugged in with the black wire (ground) closest to the fuse on the spike. we have the pressure switch wired with a pwm cable, the signal (white) and the ground (black) with the red (power) not connected to anything, that cable is plugged into the 1st slot on the digital sidecar "Digital I/O" section.
The spike is plugged into the 1st relay spot on the digital sidecar.
we are sure that me have the spike wired correctly, if we take the pwm cable from the spike and place it in the DIO as apposed to the relay spot it will allow the compressor to run and keep filling until you remove the wire. also when we fill the tanks when it gets up to about 115-120psig you can see the pressure switch close on the main dashboard.
...and thanks for the help on this problem, Team 1737 is very grateful for it.
Unread 16-02-2009, 13:01
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
ok, well, as far as i can see you are doing it right (at least if i followed those messy wires correctly), but im sorta baffled why you didnt use the enums to specify the dio, the slot, and the relay port. I think that may be where your problem is stepping in.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 16-02-2009, 13:14
See all those red dots on your Compressor Open VI? They're telling you something. You can't always use an integer when an enumerated type is expected. Something is probably off by one from what you think you're telling it.
Delete those integer constants (remembering what they are, of course). Right-click on each input of the VI and choose "Create constant" from the pop-up menu. Then you can choose the correct relay number and module number and Digital I/O number from the enumerated constants that appear.
Unread 16-02-2009, 13:50
replacing the integers with the constants worked, thank you very much for your help.
Need help with code. hawk_11 Programming 6 06-02-2005 13:56
Help With Compressor Code fred Programming 6 21-01-2005 17:40
Need help with my code jaywion Programming 9 20-03-2004 11:32
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
