Go to Post It's more of a "gracious professionalism" thing. - Matt Leese [more]
Unread 15-02-2009, 22:13
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
smcmahon is an unknown quantity at this point
questions regarding <R73> [pneumatics rules]
We're using pneumatics for the FIRST time this year. We have what would be considered an OFF-board compressor. <R73> states:
<R73> If pneumatic components are used on the ROBOT, the pneumatic system on the ROBOT must contain as a minimum the following components, connected in accordance with this section.
A. Pressure gauges to display the “stored” and “working” air pressure (see Rule <R75>),
B. A pressure relief valve, calibrated and set to release at 125psi (see Rule <R76>),
C. A pressure switch, calibrated and connected to the ROBOT control system (see Rule <R77>),
D. An easily visible and accessible pressure vent valve to manually relieve the stored pressure
(see Rule <R78>).
[A.] We have a pressure gauge on our system, that will show what the current PSI is onboard. It's mounted inline after where the air initially comes in, and before everything else. Sound OK? With the regulator more than likely being OFF-board, then we'd need only one gauge on the robot I imagine.
[B.] We need to install this directly on the (OFF-board) compressor.
[C.] We do not have this. It seems, to me, that there is no use for it since we have no ON-board compressor. But the rule states we need it, as a minimum. So? What would it get hooked up to? We're confused.
[D.] We have this on the robot, right where the main air comes in. If I understand correctly, we need another one on the other end, coming out of the compressor? <R78>
Unread 15-02-2009, 22:37
Re: questions regarding <R73> [pneumatics rules]
Presumably. However, why do you only want 60 PSI on the robot? Presumably, you'd want 120 PSI, which means two gauges. Also, you'll need a gauge on the compressor, most likely.
Correct. <R76>
Put it on the compressor side. Because you're running only 60PSI on the robot, your high-pressure side is the compressor and anything with it. Then make darn sure your regulator goes with the compressor. <R77> (Though, if you put more high-pressure stuff on the robot, put it there instead.)
Correct.
Now, remember: Anything said here is unofficial. If you want an official answer, ask the Q&A.
Unread 16-02-2009, 10:32
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Thanks EricH. We're actually on terms with the LGI for our Regional, so I've also forwarded these clarification requests to him as well. Between your insight and his, we should be legal and ready to go by day's end.
Unread 16-02-2009, 12:47
45Auto's Avatar
45Auto 45Auto is offline
FRC #2992
45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future
We used an off-board compressor two years ago. Our understanding was that all components that would be in an ON-BOARD system still had to be there except for the compressor. We had 2 electrical leads coming from our ON-BOARD switch that we would connect to the compresssor, and had a quick connect air fitting on the compressor that connected to the feed line on the robot. All relief valves, regulators, gauges, etc were on the robot. Only thing not on the robot was the compressor itself.
Had no problems with inspections at all at either the regionals or championship.
Two Questions Regarding Hurdling thefro526 Rules/Strategy 18 24-03-2008 23:35
Regarding end game rules tbd Rules/Strategy 10 22-02-2008 13:48
Questions Regarding Rules compasswilting Rules/Strategy 6 13-01-2007 14:56
Questions regarding Vex Competition team399 FIRST Tech Challenge 4 15-12-2005 15:41
Rules regarding sensors/processors phrontist General Forum 11 09-03-2004 22:38
