Go to Post Yes, a good driver can effectively be the element that closes the loop, but only when there is a driver at the controls. - Alan Anderson [more]
Unread 16-02-2009, 14:21
grosh grosh is offline
FRC #2147
grosh is an unknown quantity at this point
Joystick Buttons?
I need help programming the KOP joystick buttons in LabView using the Basic Framework. We are trying to turn a motor clockwise when Joystick button 4 is pressed then invert the motor when Joystick button 5 is pressed. With our current code we can get button 5 to spin a motor, BUT nothing happens when button 4 is pressed.
We have tried a number of different fixes. It seem that this multiple button issue always occurs when we try to program more than one button to activate the same motor. I've attached a picture of our recent failure. Can anyone help!
Unread 16-02-2009, 14:28
rhoads2234's Avatar
rhoads2234 rhoads2234 is offline
AKA: Erin
FRC #2234
rhoads2234 will become famous soon enough
Re: Joystick Buttons?
You've opened a motor twice. Try sending a wire branch to the second case stament instead of opening PWM 5 twice.
Also nestle the case statements - so put the button 5 case statment within the false of the button 4 statement or vise versa. Make sense?
ALWAYS a mechanical problem!
Unread 16-02-2009, 15:08
FRC #2147
Would nesting make the motor spin when NO buttons are pressed? We don't want the motors to spin unless a button is pressed.
Opening the motors twice was a failed fix. We have changed that back.
Unread 16-02-2009, 15:16
dqmot17's Avatar
dqmot17 dqmot17 is offline
Orange Hat
FRC #0247 (Da Bears)
Team Role: Webmaster
dqmot17 can only hope to improve
Send a message via AIM to dqmot17
you can't open a motor twice. It will have a race condition and they will fight each other. We had that with tank drive, so if that isn't your problem, then look else where.
Also, try making a sub vi for the opening of motors, then a sub vi for logic depending on the values, then make a close sub vi.
2009 Championship Finalists & 3 Blue Banners
Unread 16-02-2009, 16:03
FRC #2147
If we take the SetSpeed=0 out of the false conditions we can get both buttons to work. HOWEVER, now it doesn't stop.....!
Does that help anyone?
Unread 16-02-2009, 16:21
dqmot17's Avatar
Orange Hat
make both of the joysticks come in on a Or statement. (the image is my code)
Unread 16-02-2009, 16:25
rhoads2234's Avatar
AKA: Erin
FRC #2234
your set speed to 0 would be in the false statement of the interior case statement.
This would make the motor stop when no buttons are pressed but if one or the other is, it will send that value.
-so I will walk you through it (I don't have Labview on this computer)
Open Motor
get button 5
___Case statement
_____true
________set speed to Right Crab speed inverse
_____false
________get button 4
________Case Statement
__________true
_____________set speed to Right Crab speed
__________false
_____________set speed to 0
Unread 16-02-2009, 16:59
FRC #2147
I think we got it!!!!!!!!!!!!!!!!!!! Wow, thanks everyone. I think we might be ready to ship.
Labview Joystick Buttons... team877 NI LabVIEW 36 17-02-2009 19:23
Joystick buttons Team_2547 NI LabVIEW 1 24-01-2009 19:42
Joystick Buttons KRibordy C/C++ 6 24-01-2009 10:06
Buttons to Pins on Joystick yarb65 Electrical 1 24-08-2007 20:39
Assigning Joystick buttons.... archiver 2001 5 24-06-2002 00:59
