Box size
hey
what's the weight of the box with the robot and the battery's box and the battary itself? thx 3083 |
Re: Box size
According to section 4.4.1.1.5 "Weigh 400 pounds or less when loaded to avoid drayage overage charges." 2.2 pounds is 1 kilo. Best of luck!
Brian Holmgren The Gearheads Coach Team 1981 |
Re: Box size
I weighed our 117lb robot with 11 lb bumpers and 2 batteries at 389 lbs in the crate with packaging to protect the robot.
Make sure your crate is built to specifications and you shouldn't tip the 400 lb weight limit. |
Re: Box size
The weight of the box depends, of course, upon how it is built. I have seen crates that weight 400 pounds by themselves.
The box + robot + batteries can weigh a lot, there is no real limit, but the 'free' shipping goes up to 400 pounds. 401 and you pay for the next hundredweight (meaning 401 = 500), and those charges can get into several hundred dollars quickly. That means it is in your best interest to limit the weight to 400 lbs if at all possible. |
| pic: we decided to leave our electronics box as the cardboard box FIRST gave us, it was prelabeled. | bubbablahmon | Extra Discussion | 15 | 22-01-2008 09:40 |
| Measuring box size | Max Brin | Technical Discussion | 1 | 26-01-2006 12:16 |
| Size Of control box | rcubes85 | Control System | 8 | 18-02-2005 10:22 |
| control box size | gail | OCCRA | 2 | 24-09-2002 05:30 |
| Weird Moving-Box (or any Big Box) uses | Kristina | Chit-Chat | 5 | 25-06-2002 17:19 |
