Go to Post Blasphemy! Everyone knows Mountain Dew is roboteer fuel. - Racer26 [more]
Unread 16-02-2009, 17:03
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: 25 Chain Part
The usual approach to doing chain is to use the Roller Chain Design Accelerator. In an assembly, click on "Assembly Panel" on the left side of the screen and select Design Accelerator, then click on the arrow next to V-Belts and click Roller Chain. You can then drop down on chain type and select ANSI B29.1 25 Pitch chain in the category labelled "ASME B29.1 Precision power transmission bush chains," it's in the upper left on my installation. You'll then need to specify design constraints that allow Inventor to create a custom length of the right length. For more details on this, click the help icon in the lower left of the chains window, or consult the tutorials on FIRSTbase. There also appears to be a tuturial video available on the Autodesk site.
Good luck,
--Ryan
FRC 766, 2015-, Mentor
Chain cz2062 Inventor 20 03-02-2009 16:57
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
25 or 35 chain? Alan Ing Technical Discussion 24 02-03-2003 13:56
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
chain Lake Orion OCCRA 1 30-09-2001 13:20
