Programming Multiple Joysticks
I'm having a huge problem, whenever I try and use more than 1 joystick, the VIs for the second on reset to joystick 1.
also when I change the pwm, it resets as well, I know it's probably a easy solution that will be really obvious, but I really need to know. |
Re: Programming Multiple Joysticks
Make sure you are actually opening the PWM and Joystick VIs. If you right click on a Get and Create a refnum, that is a constant and isn't registered properly.
If this isn't anywhere close, please post a picture. Greg McKaskle |
| [FTC]: Multiple Programs or One Program with Multiple Auto Modes | kevin51292 | FIRST Tech Challenge | 4 | 02-01-2009 20:37 |
| Hosting multiple sites in multiple VMs | EHaskins | Website Design/Showcase | 6 | 22-12-2007 01:09 |
| Programming joysticks | NoRemorse | Programming | 29 | 24-02-2004 20:26 |
| AVB joysticks..and other analogue joysticks | tml240 | Kit & Additional Hardware | 6 | 07-02-2004 12:45 |
