Go to Post I'm not worried about talking to the robot, but I am worried about when the robot starts talking back... - Moros [more]
Unread 16-02-2009, 19:31
AKA: Dr. Brooks
no team (WRRF)
Re: Voltage doesn't display
You must have the analog input in the cRIO, and you must
put the little jumper on that connects the battery voltage to
analog input 8. Not only is it a good idea, it is required by
the rules.
See page 22 of the Control System Component Datasheets
Eugene
Unread 16-02-2009, 23:25
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
The jumper is on the analog breakout board, which should be installed on the analog module in slot 1. Also make sure there is power to the analog breakout board. It should be connected to a 12 volt outlet of the power distribution board and make sure it has a breaker and that the wires to the PD board are inserted properly.
Brian
Brian K
Team 1225 Robotics Mentor
Unread 17-02-2009, 00:14
Our team followed the explicit rules yet ours shows 0.00 as well. Anyone know the reasoning for this?
And yes, all directions were followed and triple checked by our elec engineer as well.
Unread 17-02-2009, 00:28
The system is reporting zero volts. What voltage do you measure on the power connection on the Analog Breakout? Is its green LED lit?
OI Display problem? Shu Song Control System 4 01-02-2005 20:42
OI Display problem? Shu Song Electrical 4 01-02-2005 20:42
OI Voltage JAH Electrical 7 12-11-2004 20:01
Voltage Byte -> True Voltage Ulibrium Technical Discussion 11 01-03-2002 08:55
LCD display James Crivellone Rules/Strategy 6 06-01-2002 10:22
