Autonomous == Disabled?
So, I'm trying to test autonomous code, yet for some reason whenever I switch to autonomous it automatically disables it and doesn't let me enable it. Anyone know what's up with that?
Re: Autonomous == Disabled?
Most likely the "watchdog"(a safety system that prevents a crashed robot from just taking off in some random direction) is detecting a failure and shutting down the system. Check to make sure that you are feeding the watchdog--if you are, you likely have some condition in your autonomous that is causing the system to lag or crash.
Alright, I'll check it out, thanks a bunch.
The LabVIEW Frameworks have the autonomous code disabled by default and you get the blinking light.
There's a little True/False feeding the outside of the loop that comes set to False to prevent auto code from running. |
| DS always disabled | intellec7 | FRC Control System | 10 | 10-02-2009 23:49 |
| Suddenly disabled?!? | Mr. E | Technical Discussion | 16 | 05-02-2009 12:01 |
| Disabled drivers | Kevin Sevcik | General Forum | 8 | 24-09-2007 22:14 |
| disabled typing | Devo1098 | Programming | 2 | 22-03-2007 18:43 |
| Disabled? | Ryan F. | General Forum | 5 | 29-03-2004 18:03 |
