Go to Post Because when you build the people and the team, building the robot comes much easier. - Koko Ed [more]
Unread 16-02-2009, 19:54
Re: Programing buttons in labview
The behavior you describe still sounds like a breakpoint. There are actually two types.
The most precise is the one put on nodes and wires. It looks like a red border around the node, or a red dot on a wire.
The second type is the pause button at the top of the window. This is a button you can just push at any point to pause execution. If a subVI has the pause set, then each time the subVI is called, it will stop at the first node, which could be an unbundle.
The other possibility is that there could be hidden code -- code under the edge of a structure or underneath a structure. Clearly this isn't well written code if it happens, but I've seen it on more than one occasion. In the edit menu is an item for removing Breakpoints from hierarchy. You might want to give that a try.
Greg McKaskle
Labview Joystick Buttons... team877 NI LabVIEW 36 17-02-2009 19:23
Programing camera in labview frcchile NI LabVIEW 1 23-01-2009 13:03
buttons in LabView Pneumaticsman NI LabVIEW 4 12-01-2009 18:14
Programing a Digital Input on the DS in Labview popo308 NI LabVIEW 6 16-12-2008 06:11
Programing joystick buttons Shivang1923 Programming 8 09-02-2008 16:21
