Re: How to set the deadband in motor vi
If you are talking about setting the motor controller's deadband, it can probably be done, but I'm not familiar with it. You can get the same effect by putting a deadband inline before the call to the motor. The deadband implementation will be some comparisons that select zero or the number depending on a comparison. The real LV control toolkit ships a deadband VI, but I couldn't find it when doing the servo stuff, so I wrote my own. If you need it much, you may want to write your own as a subVI. That way you can send in one limit, two limits, etc.
Greg McKaskle |
| Labview servo motor PWM correlation to set VI | mbone206 | NI LabVIEW | 4 | 30-01-2009 14:58 |
| How to end an auto mode after gyro gets out of deadband | kiettyyyy | Programming | 17 | 20-04-2006 07:59 |
| How to set up and run a FF League properly. | Alex Cormier | Fantasy FIRST | 4 | 27-02-2006 17:18 |
| Running a motor for a set time in auton | Morgoth | Programming | 5 | 11-03-2003 13:59 |
| How do you set a speed limit on the servo | Fares | Programming | 6 | 01-01-2003 15:04 |
