Go to Post Finally, I would like to thank my wife (I hope she remembers me.) To all the FIRST widows out there, THANK YOU! - Ken Loyd [more]
Unread 16-02-2009, 11:57
RickErmer RickErmer is offline
FRC #0073
RickErmer is an unknown quantity at this point
How to set the deadband in motor vi
How do you set the deadband in motor vi? I would actually like to set a non-symmetric deadband, but can't figure out how to set one at all.
Thanks,
Rick
Team 73
Unread 16-02-2009, 20:07
Re: How to set the deadband in motor vi
If you are talking about setting the motor controller's deadband, it can probably be done, but I'm not familiar with it. You can get the same effect by putting a deadband inline before the call to the motor. The deadband implementation will be some comparisons that select zero or the number depending on a comparison. The real LV control toolkit ships a deadband VI, but I couldn't find it when doing the servo stuff, so I wrote my own. If you need it much, you may want to write your own as a subVI. That way you can send in one limit, two limits, etc.
Greg McKaskle
Labview servo motor PWM correlation to set VI mbone206 NI LabVIEW 4 30-01-2009 14:58
How to end an auto mode after gyro gets out of deadband kiettyyyy Programming 17 20-04-2006 07:59
How to set up and run a FF League properly. Alex Cormier Fantasy FIRST 4 27-02-2006 17:18
Running a motor for a set time in auton Morgoth Programming 5 11-03-2003 13:59
How do you set a speed limit on the servo Fares Programming 6 01-01-2003 15:04
