Go to Post Striving to build the "best robot" is a fine goal -- don't hate on it. - JVN [more]
Unread 16-02-2009, 16:16
goodsky's Avatar
goodsky goodsky is offline
Programming Mentor
AKA: Skyler
FRC #1902 (Exploding Bacon)
goodsky has a spectacular aura aboutgoodsky has a spectacular aura aboutgoodsky has a spectacular aura about
cRio resetting itself, too low voltage?
We are having a problem. As we are testing all of the systems in our robot, the cRio will randomly stop, and then come back on twenty seconds or so later like when we reset it.
Watching the voltage indicator on the DS it appears as if this happens around 11.5V ... is that right? Is there a setting wrong somewhere? Any ideas?
OINK OINK BOOM!!!
Unread 16-02-2009, 16:21
Re: cRio resetting itself, too low voltage?
This behaviour usually happens when you plug the cRIO into something other than its dedicated 24V supply. Can you post a picture of your wiring?
Unread 16-02-2009, 17:12
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Are you loading the battery, e.g. running the motors and slamming them into reverse? Depending on your battery you could see a droop which would cause the 24V to drop and reset the controller.
Unread 16-02-2009, 20:34
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
It was plugged into 24V. It may have been low/bad battery. Just wanted to be sure this was not a usually situation.
Doug Leppard
Unread 16-02-2009, 20:35
AKA: Chris Rake
no team (Athena)
Not usual at all - in fact I would classify it as "something is wrong", most likely with the power supply / battery.
Unread 16-02-2009, 20:41
There are some bad batteries floating around from 2008. They will give good open circuit voltage and then die horribly under a load.
To my knowledge we haven't had a broken 24V supply yet, but this doesn't mean that it couldn't happen. If it isn't the battery, we may need to look deeper.
Unread 17-02-2009, 09:22
We were using the 2008 battery, trying to save competition batteries.
So most likley that is what it was.
Thanks for the assurance.
Doug Leppard
cRIO low execution rate Anne_droid C/C++ 1 15-02-2009 17:38
Gyro resetting and recalling? Tom Line Programming 1 17-02-2008 09:05
ADXRS150 default voltage is too low.. hinewwiner Technical Discussion 1 10-02-2008 05:12
Bug: Login Problems - Session timeout value too low? DanL CD Forum Support 4 09-01-2004 16:33
Computer resetting? David Kelly Chit-Chat 0 12-08-2003 17:21
