Go to Post Yes, machining a dog profile into a steel sprocket on a manual mill was an experience filled with pain and regret. - Joe G. [more]
Unread 16-02-2009, 19:16
Lilszamora's Avatar
Lilszamora Lilszamora is offline
Computer Consultant
AKA: Sammy
FRC #0393 (Full Metal Jackets)
Team Role: Animator
Lilszamora is an unknown quantity at this point
Send a message via AIM to Lilszamora Send a message via MSN to Lilszamora Send a message via Yahoo to Lilszamora
Programming Multiple Joysticks
I'm having a huge problem, whenever I try and use more than 1 joystick, the VIs for the second on reset to joystick 1.
also when I change the pwm, it resets as well, I know it's probably a easy solution that will be really obvious, but I really need to know.
Unread 16-02-2009, 22:02
Re: Programming Multiple Joysticks
Make sure you are actually opening the PWM and Joystick VIs. If you right click on a Get and Create a refnum, that is a constant and isn't registered properly.
If this isn't anywhere close, please post a picture.
Greg McKaskle
[FTC]: Multiple Programs or One Program with Multiple Auto Modes kevin51292 FIRST Tech Challenge 4 02-01-2009 20:37
Hosting multiple sites in multiple VMs EHaskins Website Design/Showcase 6 22-12-2007 01:09
Programming joysticks NoRemorse Programming 29 24-02-2004 20:26
AVB joysticks..and other analogue joysticks tml240 Kit & Additional Hardware 6 07-02-2004 12:45
