Go to Post Remember kids, it's not about the speed of your drive train, it's how you use it - Michael Corsetto [more]
Unread 16-02-2009, 22:59
Re: Data delay between Crio and DS
Originally Posted by PurpleHaze View Post
Our camera code causes the robot to have a delay with receiving inputs of about a second. It is running in its own parallel loop, and yet it affects the whole system.
Add a Delay VI inside your camera loop to keep it from running at full throttle. Suitably chosen, that delay will give the rest of your code a chance to run.
cRIO Program Delay bomber7 Programming 2 29-01-2009 21:35
Capture Data from the cRio goodsky Programming 2 13-01-2009 21:27
EDU-MINI RC Solenoid Switching times and Delay time? Generalx5 Technical Discussion 0 25-01-2007 01:32
interference between wires and connectors Dan Zollman Inventor 5 18-12-2006 15:11
Delay in results and awards: drying out FRCOps Championship Event 0 01-05-2002 10:46
