Go to Post Picking up tetra's is going to be as easy as picking up a person of the opposite sex. While a select few will master it; others will be bumbling maroons.. - Elgin Clock [more]
Unread 16-02-2009, 17:08
CHSboy CHSboy is offline
FRC #2153
CHSboy is an unknown quantity at this point
Wiring the wireless bridge to the robot
Does anyone have a way of doing this? A few members of my team tried to splice the adapter (not sure if that's the right term), and well, either the bridge is fried, or the adapter for it is fried.
Any suggestions would be very much appreciated, especially with the lack of time.
~CHSboy
Unread 16-02-2009, 17:22
Re: Wiring the wireless bridge to the robot
Please refer to page 16 of http://www.usfirst.org/uploadedFiles...s-Rev-0-5a.pdf
Unread 16-02-2009, 17:33
pacoliketaco's Avatar
pacoliketaco pacoliketaco is offline
Alumni
FRC #1807 (Redbird Robotics)
pacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to behold
Send a message via AIM to pacoliketaco Send a message via Yahoo to pacoliketaco
make sure you connect the right wire to the + and - terminals. the manual states that the striped wire (has white marks on it) is the positive lead. it sounds as if you may have switched them by accident.
Pace Nalbone
Carnegie Mellon University
Mechanical Engineering Class of 2013
2009 NYC Winner - 56 and 1796
(2009 Regional Record: 18-0-7 wins/ties/losses)
Unread 16-02-2009, 18:13
FRC #2153
Okay, I got the connector and what not. How exactly do you get the wires in it? I know which goes where, but I wasn't watching anyone doing this. I was waiting for it to be done so I could test the programming, seeing as they did this without my knowledge before I could do any testing.
Unread 16-02-2009, 23:19
Here's what Section 3.2.6 Troubleshooting and FAQ of the 2009 FRC Control System Manual has to say about that:
How do I build a cable for passing 12V power to the WiFi adapter?
  • Take the module's power adapter and cut the wire off close to the Wall-Wart.
  • Separate the wires and strip 7mm off the ends.
  • To insert wire into a WAGO 734-102 connector, push down on the actuation port in back. Alternatively, use the plastic actuation lever.
  • Insert the positive (striped) wire in the right port of the WAGO 734-102 connector.
  • Insert the negative wire in the left port of the WAGO 734-102 connector.
  • Give a smart tug to verify the connection is secure.
  • Insert the WAGO 734-102 into the mating connector on the PD.
  • Power the PD, and verify that the barrel connector's centor conductor is positive.
Unread 16-02-2009, 23:30
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Its a wego connector. Use the wego tool or a small screwdriver to open the connector and insert the stripped wire. You are connecting the wireless bridge power to the 12 volt connector on the power distribution board right?
Brian
Brian K
Team 1225 Robotics Mentor
Wireless bridge not allowing IP change Lord Byron FRC Control System 6 15-01-2009 17:55
Problems "Seeing" the Wireless Bridge Chipawa FRC Control System 4 11-01-2009 18:58
Source for Wireless Bridge Gary Bonner FRC Control System 1 07-01-2009 20:57
Wireless Bridge to Nowhere(Help Please!) TeknicllyInsane General Forum 3 11-12-2008 22:40
Gus can put the big balls on the goals on the bridge!!! archiver 2001 0 24-06-2002 01:30
