Go to Post Just because its a robotics competition does not mean everybody is a big dork. - Taxi Quinn [more]
Unread 16-02-2009, 23:53
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
Dashboard Error 74
I've recently started getting this error when I try to run the dashboard.
Error 74 has occured at Unflatten from String in DashboardMain.vi
Possible reasons:
Memory or data structure corrupt
I have a Sub-VI in which I am sending data from the 3 of the DS analog inputs to the dashboard using the method described in the document posted her:
http://decibel.ni.com/content/docs/DOC-2978
I created the dashboard typedef with three numeric indicators in a cluster and set the typedef to Strict Type Def.
I am running 3.0a and have rebuilt the dashboard since upgrading.
Any ideas what is causing this? Does it matter if the subVI sending data to the dashboard is used in several different locations in the code?
Eric
Unread 17-02-2009, 09:54
Re: Dashboard Error 74
I can't be specific without looking at the code or debugging it, but this error means that the buffer doesn't have the right amount of data to unflatten. Put a probe on the dashboard string and see if you can make sense of the string. Also check that the decode type matches what you expect. If the encode type and decode type differ, you will either get this message or just leave data off the end.
Greg McKaskle
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
Dashboard Error Bytes Josh Hambright National Instruments LabVIEW and Data Acquisition 0 16-04-2006 13:32
Labview Dashboard and updated IFI dashboard spec Joe Ross LabView and Data Acquisition 1 04-04-2006 02:04
Error in dashboard spec Don Reid Programming 6 09-02-2006 12:39
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
