Go to Post Hack saws are for hack work, the kind we don't do. - sanddrag [more]
Unread 17-02-2009, 00:46
csshih csshih is offline
IT pwnage.
AKA: Craig
FRC #0649
Team Role: Communications
csshih is an unknown quantity at this point
URGENT(ish): Twitchy motors
our motors sometimes twitch around even though the pwm values are zeroed.
all of our firmware and software(Labview) is up to date
does anyone know whats wrong/ have similar issues?
Unread 17-02-2009, 06:49
Re: URGENT(ish): Twitchy motors
Craig,
Are you using Jaguars or Victors? I have noted some twitching with the Jaguars we are testing.
Unread 17-02-2009, 11:10
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
Probably too late now--but this could be a calibration problem. You should look up the calibration procedure for whatever speed controller you're using and recalibrate them.
Get yer robot source code here!
Unread 17-02-2009, 11:37
A noisy PWM signal to the speed controller might do this, but there's no obvious way for that to happen. Unless maybe your Digital Sidecar doesn't have a good 12V power feed, and it's stealing current from the Digital I/O module's output? It's always worth checking to make sure the power cord is plugged in and providing power.
Unread 17-02-2009, 11:56
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
We noticed that our robot will do the same thing from time to time. We traced the problem back to a loose power connection on the power distribution board. When you lose power for a moment, the robot will continue to do the last command it received for a short period of time. For us, it would go into a short loop (~ .25 seconds) and twitch.
Unread 23-02-2009, 01:08
IT pwnage.
AKA: Craig
FRC #0649
we're using victor for the launcher.. which is what's twitching, but we had a jag twitch too, but it stopped.
Unread 23-02-2009, 07:13
Jared Russell's Avatar
Taking a year (mostly) off
My money is on a calibration issue.
Can you print out the PWM command to verify that it isn't something wonky in the program?
Unread 23-02-2009, 14:52
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
I've seen all of our motors (on Jaguars) twitch slightly upon rebooting the cRio from the DS. It doesn't happen all the time. This seems consistent with other comments indicating a twitch upon loss of a signal.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 23-02-2009, 15:15
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
We have seen the same behavior on rebooting the cRio.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 23-02-2009, 16:12
On rebooting the cRIO, sure, we've seen twitching as well. However I don't *think* that this is the issue the thread starter was talking about.
Unread 25-02-2009, 22:32
VEI Dude's Avatar
VEI Dude VEI Dude is offline
Mentor 4024, 4013
AKA: Neil the Real Deal
FRC #4013 (Jokers & Clockwork Mania)
VEI Dude has a spectacular aura aboutVEI Dude has a spectacular aura about
I haven't really touched any of the controls at this point, but I do remember reading something about the PWM being the same as a servo PWM signal. If so, you should be able to isolate the problem with a servo or a servo tester (to generater servo signals).
Also, I saw on ours that some of the ring terminals were placed under the metal pad (not on top, between the pad and screw), so the connection was not secure. I thought it could be a flaky signal, so perhaps check for that just in case.
Cheers,
-Neil.
Unread 02-03-2009, 12:47
IT pwnage.
AKA: Craig
FRC #0649
Sorry guys, I am unable to provide more information,
as our robot is now in the realm of Fedex.
The twitching does not only come up with the boot of the cRIO, it continues as long as control is activated. when the system is booted up, it is fine.
also, strangely enough, the twitching seems to be systematic.
thank you guys for your help.
Unread 02-03-2009, 20:31
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
Are you using an analog sensor to provide feedback to a control loop controlling this motor? There is an issue with faulty code giving false analog signals which could be causing your PID to make the motors twitch...
http://forums.usfirst.org/showthread.php?t=12020
http://decibel.ni.com/content/thread/2325?tstart=0
http://www.chiefdelphi.com/forums/sh...ad.php?t=73640
http://www.chiefdelphi.com/forums/sh...ad.php?t=75067
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 09-03-2009, 18:56
Garii's Avatar
Garii Garii is offline
Registered Abuser
AKA: Jared Hankle
FRC #3044 (BE4)
Garii is an unknown quantity at this point
Send a message via AIM to Garii
Actually, I had a problem with this, we were using a feedback node though an and gate that allowed us to turn on our motors and keep them on until the button was pressed again.
for some reason it was the boolean feedback node, I removed it and everything work fine except everyone was annoyed when I told them they had to hold the button instead of pressing it =p
-The Garii- aka Jared Hankle
Ballston Spa Labview Programmer
new team slogan-"Can I Get Some Linux With These Fries?"
Unread 09-03-2009, 23:42
AKA: Dr. Brooks
no team (WRRF)
There is an update of WPIlib that is reputed to resolve
the problem with the analog inputs. It also updates a
lot of other things...
http://first.wpi.edu/FRC/frcupdates.html
Motors, Motors, and More Motors 1033missions Motors 1 09-02-2006 18:46
Motors.. and more motors.. How many on your 2004 bot? OneAngryDaisy Motors 33 23-02-2004 00:46
Matching Drill Motors and Fischer-Price Motors archiver 2001 5 24-06-2002 00:51
Fisher Price Motors for Drill Motors archiver 2001 0 24-06-2002 00:22
F.P. Motors & gearbox for $12.50 Window Motors $19.50 archiver 2001 1 23-06-2002 23:05
