Go to Post If you always do what you’ve always done, you’ll always get what you’ve always gotten. - rourke [more]
Unread 17-02-2009, 04:20
vamfun vamfun is online now
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
WPILIB Encoder SetMInRate() Problem
When we use the GetRate() wpilib encoder method, the rate works except that we get an "inf" value when the encoders are still. The SetMinRate() or SetMaxPeriod() methods should force the output to zero the way I understand it. We tried both but still get the "inf" with the printout.
We use C++ and use this in the constructor:
encoder->SetMinRate(1.); //to set min rate to 1 in per second
Any ideas?
Unread 28-02-2009, 17:58
AKA: Chris
FRC #0599 (Robodox)
Re: WPILIB Encoder SetMInRate() Problem
This has been addressed at
http://forums.usfirst.org/showthread...7884#post27884
Screwing Encoder into Encoder Mount? Adrien Electrical 3 25-01-2009 18:14
Using WPILib RyanW Programming 1 19-01-2008 17:15
Problem using VEX shaft encoder jskene Programming 15 28-10-2007 22:33
Encoder Problem DustinB_3 Programming 22 03-01-2007 20:42
Strange Encoder Problem AIBob Electrical 3 20-02-2005 22:20
