Re: 1 Jag and 1 Victor not responding correctly.
This is probably not your problem, but it's easy to check: is the Digital Sidecar getting good 12V power? Look to see that the 12V LED is lit. Measure the voltage on the white WAGO power connector.
(The reason you might see this behavior if there's a power problem is that "sneakage" from the PWM signals is barely enough to keep the Digital Sidecar sort of working...until you call for reverse, and the pulse width drops.) |
Swap a working Jag with #8 and see if the problem moves with the Jaguar or stays with it. You might have a faulty jaguar. If you do, be sure to contact luminary micro for a replacement.
Also, make sure this isn't a Jaguar your team wired incorrectly / reworked. I would not trust any Jaguar after it sustains the impact of incorrect wiring (even after rework - which I think is illegal anyways - there is no telling what remains damaged yet unseen).
http://www.chiefdelphi.com/forums/sh...highlight=jags Regards, Scott |
The jaguars work correctly.
I just changed the programation a bit ![]() I didn't like it much but it was a solution |
| 2009 Camera and Jag inventor models problem | Creator Mat | CAD | 5 | 08-03-2009 14:05 |
| CRio Not Responding | Shadow_Cat | NI LabVIEW | 7 | 13-02-2009 08:12 |
| NASA/VCU is NOT scoring Hybrid Mode correctly!!! | Racer26 | Regional Competitions | 13 | 07-03-2008 20:44 |
| Pinion not machined correctly | Coachmac | Kit & Additional Hardware | 2 | 14-01-2005 10:28 |
| Victor 884's not behaving the same as Victor 883's | programmer1 | Programming | 13 | 10-03-2004 21:51 |
